63 CA Patrol - "Pumpkin"
Postby nobueno » Thu Jan 30, 2020 3:13 pm
Patrollers-
I got tired of staring at the old girl while she waits for her springs. I took some pics to remember where we started.
-NB
nobueno Offline
Has thanked: 1 time
Been thanked: 18 times
Postby RiverPatrol » Thu Jan 30, 2020 6:55 pm
Great pictures! :clap:
Images: 959
Has thanked: 6774 times
Been thanked: 2287 times
Postby nobueno » Wed Apr 15, 2020 2:59 pm
Alright... After a little more than 3 months I just got a call yesterday that said the springs will be here Friday. I'm excited to finally get the old girl back on the road! Hopefully I can knock it out this weekend.
A few questions for anyone with answers:
What swaybar links should I get for +2?
The parts page seems to be down, where can I find new brake lines?
Does Raul make the soft top as well or just the frame?
-NB
nobueno Offline
Has thanked: 1 time
Postby Edgar » Wed Apr 15, 2020 3:32 pm
Raul makes the soft top as well and makes a fine product.
Edgar Offline
Images: 74
Has thanked: 225 times
Been thanked: 115 times
Postby nobueno » Wed May 20, 2020 9:51 pm
So as it turns out the weekend leaf spring project has turned into a 3 weekend endeavor so far with 3 leaf springs in. The front is completely done and I'll have the right rear done this weekend.
My brakes have been leaking and I took off the hub to see brake fluid all over my front shoes... I've found the ebay link for them from AUS. Will they fit my 63? it says 67-80 I believe.
Also I still don't have rear sway bar links that are long enough. Does anyone know the proper length needed like on the Green Machine? Speaking of Green Machine, who made those shackles? I might need some for the front since it seems as if the "+2" I received has quite the rake.
-NB
nobueno Offline
Has thanked: 1 time
Postby RiverPatrol » Wed May 20, 2020 10:01 pm
Three weekends? Sounds about right for a Patrol project.
The wheel cylinders will work for your '63.
Images: 959
Postby nobueno » Sat May 30, 2020 6:02 pm
Just finished the suspension! Got the hang of it just in time to never do it again. I love the height and the angle, but my front shackles are buckling under too much load which is super annoying. I'm hoping by adding a shackle an inch or two longer will be the cure. Otherwise I'm stoked with the result. Next are tires and top removal... after I clean the garage.
-NB
nobueno Offline
Has thanked: 1 time
Postby RiverPatrol » Sun May 31, 2020 12:17 pm
Where did your leaf springs come from? I don't see a longer shackle helping that situation any.
Images: 959
Postby nobueno » Sun May 31, 2020 5:17 pm
RiverPatrol wrote:Where did your leaf springs come from? I don't see a longer shackle helping that situation any.
I got them from Atlas Suspension. In retrospect I probably should have used Alcan. I'm thinking of moving the whole bracket forward a little but. Thoughts?
nobueno Offline
Has thanked: 1 time
Postby RiverPatrol » Sun May 31, 2020 5:31 pm
It's almost as if the springs are too long. You shouldn't have to move the bracket.
Images: 959
Return to Introduce Yourself!
