Page 40 of 42
PostPosted: Tue Oct 01, 2019 11:54 am
It looks like this weekend was lazy weekend for the members. Not a single post. I'm showing withdrawal symptoms! :evil:
PostPosted: Tue Oct 01, 2019 6:58 pm
by 50car
Will be picking up another Patrol in the next couple of weeks. It's a 68 sold in 69. Strictly a parts vehicle. Owner said it ran 10 years ago when parked. It was a soft top . The b pillar and hoop over the front seat along with the tie bar to the middle of the windshield is still on vehicle. Rest of the top is gone. I will be scavenging parts for my Montana restoration. Will let members know what is available after I am done. Will post pics when I get it.
PostPosted: Tue Oct 01, 2019 9:40 pm
by PetrolPatrol
I'm working on swapping plugs, wires, and distributor in order to get it running more reliably. Sadly I have no pictures of anything at the moment. I'm going through everything looking for the size of the crankshaft bolt so I can manually turn the engine right now. So it's not been an entirely quiet weekend.
PostPosted: Mon Oct 07, 2019 9:01 am
by PetrolPatrol
PetrolPatrol wrote:I'm working on swapping plugs, wires, and distributor in order to get it running more reliably. Sadly I have no pictures of anything at the moment. I'm going through everything looking for the size of the crankshaft bolt so I can manually turn the engine right now. So it's not been an entirely quiet weekend.
And running! Got everything swapped, timing is mostly correct (I don't have a timing light, so I had to estimate it), and she drove around the block for the first time! Next up is figuring out the carburetor situation as it idles higher with the choke in than with it out.
PostPosted: Mon Oct 07, 2019 11:52 am
by mdawg4x4
That's inspiration.
That is more than I can say about my 67. I do look at it in the garage every time I come and go and say, "I'm going to get back on it and get it running as soon as possible." Possible keeps eluding me! Well, it keeps eluding my desire to mechanic on anything right now!
Just replaced calipers, rotors, and pads on the front of the old 98 TJ couple weeks ago. Looks like it has an oil leak that needs attention.
Gotta replace ball joints on the JKUR here in the next few months. And contemplating a big brake kit on it to help it slow down with the 35" tires on it.
The 67 G60 is after that,,,hopefully.
PostPosted: Mon Oct 07, 2019 5:07 pm
by curlrider11
No projects as of right now for my patrol, except to make some good room in the garage for winter storage. Don't feel like bolting the top back on any time soon with a rollbar project in the future....
Only other thing I hopefully will do this fall winter is a small write up on a front brake pad re-bonding project I want to try....
PostPosted: Sun Oct 13, 2019 9:03 pm
by 50car
Made the trip to Montana this weekend to pick up the next acquisition... I am naming it Alberton Gulch patrol.
PostPosted: Mon Oct 14, 2019 9:09 am
There's a couple of good parts in the engine compartment. How does that kind of damage even happen to a Patrol? :o
PostPosted: Mon Oct 14, 2019 2:33 pm
by 50car
It was used as a tractor to pull firewood logs out of the hills for many years. I pulled the non factory Toyota pickup seat out of it just so i could see the interior better. It was rolled at least once i was told. The remaining damage came from years of abuse pulling logs. It ran 10 years ago when parked where i saw it. And yes there are some useable parts that will be used on my Montana Patrol restoration. The owner was happy to see parts if it put to use in the restoration.
PostPosted: Thu Oct 17, 2019 11:07 am
by PetrolPatrol
Is it too early to call dibs on any parts you don't need?
PostPosted: Thu Oct 17, 2019 6:39 pm
by L60Boerne
PetrolPatrol,
I love your battle damaged Patrol. It is much more fun to drive off road vehicles without worry for scratches and paint chips. It is really fun to revive them too. You get the satisfaction of seeing each new stronger than the last new breath it takes.
Pump Up that Patrol,
PostPosted: Thu Oct 17, 2019 8:37 pm
by 50car
PetrolPatrol wrote:Is it too early to call dibs on any parts you don't need?
What parts are you looking for?
PostPosted: Fri Oct 18, 2019 7:56 am
by PetrolPatrol
I need interior bits for now. Wiper motors, horn button, ashtray cover, whatever I'm missing in those two holes, rearview mirror, any passenger side mirror, and the rear seatback to a jump seat!
PostPosted: Sat Oct 19, 2019 8:31 pm
by 50car
What year is your vehicle. Based on the picture, it shows only 2 window vents indicating 68-69. The seat backs are different for earlier years.
The hole furthest to the right is normally the heater switch. Is yours missing or do you have a heater?
PostPosted: Sun Oct 20, 2019 7:38 pm
by 50car
So I started pulling parts off the Alberton gulch Patrol today. As I was pulling the headlight chrome rings off, I made a startling discovery..... both headlights were Koito headlights. :o :o :D :D . These were ever so gently removed from the vehicle and placed onto the restoration parts pile.
Not even sure why I hadn't checked these before I pulled it a couple hundred miles home???? :oops: It would have been a sad day had these gotten broken when I had a chance to use them on my Montana Restoration project.
Original seat belts- rusty and rotten webbing.... salvageable....will be restored for Montana Project
Hood emblem -very useable for Montana project
Grill cross bar- no rust will be used for Montana project
overall this vehicle was a great find for the restoration project.
