Postby RiverPatrol » Fri Jan 24, 2020 11:55 am
You might not need a new master cylinder, probably just need to bleed the brakes real well. Even if you only replaced one wheel cylinder, you need to bleed the entire system at every wheel. Also, have you verifies that your old alternator isn't putting out? That isn't necessarily why a battery goes dead, you might have a draw in the electrical system that replacing the alternator won't help.
Images: 768
Has thanked: 4771 times
Been thanked: 1468 times
Postby PetrolPatrol » Sun Jan 26, 2020 7:55 am
RiverPatrol wrote:You might not need a new master cylinder, probably just need to bleed the brakes real well. Even if you only replaced one wheel cylinder, you need to bleed the entire system at every wheel. Also, have you verifies that your old alternator isn't putting out? That isn't necessarily why a battery goes dead, you might have a draw in the electrical system that replacing the alternator won't help.
I bled the brakes multiple times and paid someone else to do it for me just in case. Even after all that and checking to make sure the pads are adjusted it takes a pump or two to firm up. Also tested the alternator, used a voltmeter and took it to an alternator shop. It's as dead as a doorknob.
PetrolPatrol Offline
Has thanked: 5 times
Been thanked: 42 times
Postby Peter60 » Mon Jan 27, 2020 11:54 pm
[quote=I bled the brakes multiple times and paid someone else to do it for me just in case. Even after all that and checking to make sure the pads are adjusted it takes a pump or two to firm up. [/quote]
Its all in the adjustment! Just tighten them ALL up till there is just minor rubbing on the pads/drum. But then sometimes that doesn't work!
Peter60 Offline
Has thanked: 126 times
Been thanked: 186 times
Postby G60michael » Thu Feb 13, 2020 6:06 am
Some rare as hen's teeth goodies added to my Patrol Parts Stash, probably never end up using them but worth having.
The ever Illusive C216 Carrier bearings!! Having spoken to Esteban a while ago and having read several forum posts with people trying to get the right bearings to replace, most people just think would be a standards bearing number HR32209, and that's what we all order :lol:
As folks have Learnt over time, the Bearing is a Standard Number, but the tricky part of it is that the Outer Cone/Race is a special one Designated Strictly to the old G60 Patrol's, its 3mm Wider in the Cone then a Standard 32209 Bearing Cone! This is a Significate difference and involves making a spacer to space the narrower standard 32209 cone out to make up the difference of the original wider cone.
Having read a post on Facebook a bloke was after bearings and had no Luck, I also could use some to freshen a diff up that had been low on oil and surface rust had got to the bearings, not a result that will end good, I ended up doing a diff swap :lol:
having researched here, even years back now folks had trouble trying to source the correct HR32209JX, needs the JX Prefix which is the OEM Number for the Original bearing with the unique Wide cone. No results on the internet, decided to try a local bearing shop, they hunted a week and found one in there chain of suppliers, I then tried Nissan, no stock, discontinued number.
Tried another shop and they had No Listing, they offered to call NSK (the Only Manufacturer/OEM Manufacturer of these C216 Bearings) only one left in there NSK Network, Took a week and its now here as well :lol:
Decided to email NSK International as well personally and see if possible one off Re-Production would be considered, its a No Go and was Informed that its Been Discontinued for several years now, and in there NSK Global Network there is no Stock Left anywhere Globally :shock: :o
So unless someone's brought a bunch years ago and has them sitting in a box in the shed, there no loner available anywhere, all suppliers here system is linked nation wide aswell :cry:
68856886
G60michael Offline
Images: 567
Has thanked: 131 times
Been thanked: 250 times
Postby Esteban » Thu Feb 13, 2020 9:15 am
G60michael wrote:Some rare as hen's teeth goodies added to my Patrol Parts Stash, probably never end up using them but worth having...
Excellent Michael! You certainly give a new meaning to the word unobtanium !
Congratulations on your effort to find these bearings. Probably we should add a note in the compatible parts section, so people don't get frustrated trying to find these bearings, and proceed with the spacer route.
Has thanked: 3661 times
Been thanked: 1003 times
Postby G60michael » Fri Mar 13, 2020 6:59 am
Hi Guys, Hope you all had a good week, I certainly did having got a 3rd G60 currently registered. Back in 2017 a mate passed away and I inherited 3 g60s from him, this is 1 of 2 from him that I have since got registered, he would be proud of the achievement.
She is a 1/1977 G60 Patrol Factory Tub Ute with the rare as Tub Style Tub, also known as a G60-62Z (62Z Representing Tub Ute, 94Z is Cab Chassis/Table Top tray)
When I brought her home in 2017, I got her running, the fuel pump was shot so only heard it run for a few minuets at most :lol: since then I parked her in the shed and that's where she sat until a few months ago I Dragged her out to get her ready for the 2020 G60 Trip with my mates to the Vic High country again, having took the shorty last time, I decided a ute would be much less cramped and ideal for a trip.
Plenty of skinned knuckles, cursing and swearing, but once again hard work payed off and I got in there and got the job done, the key to getting a g60 roadworthy is to not sit on your hands waiting for it to fix itself, its to get in there and get it done 8-)
Yesterday she passes a Pink slip for NSW Historic Rego, Give you 60 Days of Personal driving unlimited Km's, Plus other car shows and club events are bonus days you get to drive it. Happy Day's, time to iron out any gremlins before the trip.
This is one of only 2 Known Original Tubs utes that are Registered for legal road use still 8-) The other one is a 1974 Pale Green one in Victoria owned by and old Fella, which i think may now be De-registered
Cheers G60mike
69536954
G60michael Offline
Images: 567
Postby PetrolPatrol » Sat May 09, 2020 5:13 pm
Finally did some work on the Patrol's brakes so I only have to press once. Went with the Wilwood 1" MC for 70-83 Datsun Zs, also fits some 510s and 620s.
This is not the correct size but was extremely close. Close enough that with a dremel I was able to extend the holes in the body to mount it and it only took a few minutes. Sorry, I didn't get exact measurements.
Once in the size discrepancy did bother me a bit, but I discovered that the SU Carb gasket for A-Series engines fits perfectly over it. Cleaned it up nicely and took care of any gaps or what have you.
I had also purchased some NiCop brake lines that included more than enough fittings for this project and a universal GM pushrod kit. The pushrod kit was purchased because the original rod for the MC had no way of connecting to the brake pedal and I couldn't find a Clevis end that would work locally. This kit took care of all of that as the clevis end fits perfectly and the pushrod just needed some minor modifications to work.
This picture is before it was finalized, so the brake lines are backwards. Ignore that :doh: Moore_rb did an excellent writeup on how the brake lines should go and I just followed his lead. Rear to the stock T, fronts to the stock soft line. Once installed and everything was tightened down I used the time honored tradition of trial and error to get it just right. Brakes are firm, stops on the first go, and I feel MUCH better about driving it. I still think I'm going to make some further adjustments in the future but this is good enough for a vehicle with a top speed of 60 MPH.
Not the most in depth write up, but using basic tools and with no adapters or anything like that I was able to get functioning brakes again, so I'm pleased with the results. Just took some time & elbow grease which is no different than any other job on these things (or at least on mine).
Postby Esteban » Sat May 09, 2020 6:55 pm
Great! :clap: :clap: :clap:
I'm sure other members will find this post really helpful. You've done the right thing. I think functionality beats originality when talking about brakes.
Postby ozscott » Mon Jun 22, 2020 11:09 pm
This week I finally fitted the clutch slave cylinder and new master cylinder (Protex) which, even though it stated was for up to 1980 Patrol, was in fact imperial and not metric. This has been a constant issue with the Protex master cylinders and wheel cylinders. None so far have been metric, all have been imperial, which has meant that I have had to change fittings, and make some new lines, on the brake & clutch system to accommodate. At least I know they are all new and safe.
The clutch slave cylinders available from Protex for G60 Patrols are also imperial, and do not have the mounting holes in the correct position for my 1978 G60. The union at the rear of the slave cylinder is metric on mine, and as the hose was like new I was not keen to add further expense. So I sent the old slave cylinder off for resleeve and rekit. This slave was in very poor condition, the piston rusted (what is the equivalent for alloy into metal?) into the bore, jammed solid, no hydraulic or air pressure could budge it. I was quoted $250 to resleeve, and then found a clutch specialist in Bendigo, Victoria who did the resleeve and rebuild for $75. He will get all my work from now on. He also told me if I could get the dimensions of the clutch slave return spring he can hunt through his stash for one, or get one remade. So, if anyone has the dimensions, Nissan part #46466-44000, and it would appear from the parts book that this spring ran over many years\, I would appreciate it greatly.
In my excitement to finally have all my hydraulic parts for the clutch I forgot to bench bleed the master so now have to pull it all off the truck and bleed the master. :oops:
I hope all of you are keeping well. Self isolation in the shed is like bliss ;)
ozscott Offline
Has thanked: 16 times
Been thanked: 48 times
Postby Peter60 » Thu Jul 02, 2020 7:28 pm
Ozscott
Did you find a return spring? I may have one on a wreck. WIll check next week.
Peter60 Offline
Postby PetrolPatrol » Wed Jul 15, 2020 9:23 am
Got some more minor work done lately. Thanks to the always helpful River_Patrol I got the wiring on my fuse block so it's not always hot and fixed some of the odd wiring decisions of the ghost of Patrol past - cooling fan, fuel pump, ignition, etc. Not original, but better. Installed a fuel regulator and gauge to monitor fuel flow better and make sure I don't flood anything since the Carter carb doesn't like a lot of psi. Small victory but got the spare tire mount fixed as well! Hopefully next bonus I'll have something to mount on it.
Next up is an air/fuel ratio gauge, fixing more wiring, and (I hope) finally getting some rear seats. Then some more interior clean-up and it'll be nice enough (and reliable enough) for top off driving.
Postby RiverPatrol » Wed Jul 15, 2020 9:41 am
Nice Roadster!
Images: 768
Postby PetrolPatrol » Sat Aug 01, 2020 2:59 pm
RiverPatrol wrote:Nice Roadster!
Thank you. She's got new carpet, an uprated rebuilt 1275, new paint, and is just waiting on me to stop working on the truck so I can rebuild/upgrade the suspension & install new seats.
It's nice finally having a truck! I recently moved and she fits a lot more than the Healey or Fiat could ever dream. Truck ran fantastic, brakes are good, lights never flickered, temps are great, and running back & forth she didn't hiccup once. Since I finally had it running how I wanted I ripped out the fuse block and broke some things.
Finally got the original fuse block installed. Not sure why, but it doesn't match the wiring diagram I have exactly - probably a combination of year changes, no generator, and then some other misc. wiring changes like fuel pump & radiator fan. Slight PITA, but it's much better than what was there. Huge thanks to plateaucal for this one!
Also went full Jeep Wrangler and mounted the hi-lift jack to the hood.
Since that made the hood fairly heavy I decided to add gas struts it. They're two 65lb struts and it lifts the hood smoothly and isn't difficult to lower. I used, what I believe, are two stock holes in the hood to mount them, so it doesn't lift as high as the stock prop, but I'm OK with that.
I also purchased one of the license plate lights off Ebay. It's decent quality, but looking at the paint/rust lines it seems rather small. It also required a lot of modifying to fit, more than I thought it would. Not a huge deal in the grand scheme of things, but if I was doing it again I'd look for one off a true 69 that I knew would fit better.
Now to see what parts I can find to work on next.
Postby Esteban » Sat Aug 08, 2020 2:53 pm
Finally changed the battery on mine, after 16.5 years in use. The previous one was a Korean, Solite battery. I was concern that during the winter time the battery might not be up to par. Still was giving 12.67V after sitting for a week, but the reserve capacity was not there.
I bought an Interstate battery, Group Size 34. (Model MTP-34)
Dimensions:
Length: 10-3/16"
Width: 6-13/16"
Height: 7-15/16"
I will say that the contributing factors for such a long lasting performance have been, it's location in the vehicle, outstanding construction quality (never had to clean the posts) and a voltage of around 13.7V that the regulator is controlling all the time. Since it's an electronic regulator, no chance of modifying it.
Previous
Return to General Topics
cron
