69 rat house
Postby nizmut » Sat Feb 25, 2017 11:42 pm
So I pulled the left hub and wheel bearings a few days ago. The hub is in pretty rough shape from someone setting up the wheel bearings with a chisel. That caused the o-ring on the locking hub not to seal, allowing water to enter, and rust to grow. After a lot of wire wheeling I think I can save it, but will need need to do some burr work and a secondary seal option.
So now into the fun stuff. Before you remove these 6 nuts, go buy LOTS of shop towels. First you remove the inner snap ring(You had to remove the outer one to remove the inner part of the locking hub), then remove the nuts.
The backing plate will slide off, then grab the spindle and it will slide off too.
Don't drop the stub axle, once it pivots it will fall out.
Welcome to the lots of towels part. I just slid the stub axle into the spindle and stored it in a safe place that I wouldn't be upset about the mess.
At this point it was dinner time, or any other excuse to not start cleaning that mess out.
Robin
nizmut Offline
Images: 0
Has thanked: 40 times
Been thanked: 140 times
Postby mad4hws » Sun Feb 26, 2017 6:29 am
looks like chocolate mousse.
Thanks for sharing again. this is going to be very helpful very soon as i start tearing into mine.
mad4hws Offline
Images: 211
Has thanked: 113 times
Been thanked: 175 times
Postby nizmut » Sun Feb 26, 2017 10:35 pm
OK, so after we got home from volunteering at the gem show I played in the shop a bit. Started by cleaning up the spindle and stub axle.
Then I pulled the snap ring and removed the roller bearing from the spindle. One of the cheap 4 for $10 pinch bars slid down the spindle can tap out the bearing. I have new bearings so didn't need to be overly careful. The tracta joint is a little rough and will take some cleaning up, but with the locking hubs I'll run it.
After that I pulled all the bolts from the seal retainer, and all the nuts from the kingpin bearing caps. I then used a brass drift and tapped the caps out from the inside. Don't loose the shims! Then grab the outer knuckle and give it a wiggle and the seal will pop out.
I then mucked all the grease out with rags and put it in the solvent pan. (If you are in California, Tractor Supply has a parts cleaning solution that still works)
After the outer knuckle is off it is easy to grab the inner axle and slide it out.
After the axle is out you can do some more grease mucking in the housing.
After I mucked out the housing I tapped out the races, I switched to a steel drift because I have new races and good brass drifts are expensive.
Then I had to go cook elk burger patties for my lunches next week.
Robin
nizmut Offline
Images: 0
Postby RiverPatrol » Mon Feb 27, 2017 11:02 am
Thanks for the tip on California solvent. What brand is it?
Images: 718
Has thanked: 3458 times
Been thanked: 1136 times
Postby nizmut » Mon Feb 27, 2017 11:22 pm
RiverPatrol wrote:Thanks for the tip on California solvent. What brand is it?
PSC 1000
Robin
nizmut Offline
Images: 0
Postby mad4hws » Tue Feb 28, 2017 8:20 am
nizmut wrote:............Then I had to go cook elk burger patties for my lunches next week.
Wow, that sounds better than what I'm having for lunch this week. reminds me of being home back in New Mexico. Those aren't California native Elk, are they?
mad4hws Offline
Images: 211
Postby nizmut » Thu Mar 09, 2017 4:45 am
No, Utah. No updates for a while, had my hernia repaired Monday. Just up getting an Ice Pack and some Tylenol. :lol:
Robin
nizmut Offline
Images: 0
Postby mad4hws » Thu Mar 09, 2017 9:26 am
nizmut wrote:No updates for a while, had my hernia repaired Monday. Just up getting an Ice Pack and some Tylenol. :lol:
That sounds terrible! feel better soon.
mad4hws Offline
Images: 211
Postby mdawg4x4 » Thu Mar 09, 2017 9:51 am
What he said^^
mdawg4x4 Offline
Has thanked: 242 times
Been thanked: 238 times
Postby RiverPatrol » Thu Mar 09, 2017 10:32 am
Ouch. Hope it heals quickly!
Images: 718
Postby nizmut » Fri Mar 24, 2017 3:51 pm
Well I've been cleaning up a few little things running around in sweatpants and suspenders. But now it is time to address this.
Was hoping not to go to far in, but bearings are not too expensive. Gears look good, just flat spots on the races. Got to love locking hubs and deferred maintenance, remember to spin those front gears people.
Robin
nizmut Offline
Images: 0
Postby Esteban » Sat Mar 25, 2017 12:40 pm
Looks good. Just remember, the carrier bearings are unobtanium! Only still available in Colombia from old stock. I need to update the post with what my solution was, using similar bearings.
Has thanked: 2399 times
Been thanked: 795 times
Postby nizmut » Sun Apr 16, 2017 3:39 pm
Well yesterday was a good day.
Started off by giving the cat his first bath :shock:
Then went to the gem club and slabbed up a bunch of jadite. Cleaning the saw got me ready for my next chore.
Since these came in
decided to knock out the long side seal. With that comes cleaning 48 years of grease out of the axle tube :shock: yeah, another roll of shop towels :lol:
After 8 hours of mineral oil, grease, and cleaning solvents it was dinner time.
Today it started raining way earlier then they said it would, so I'm hiding out, well except for going out in the pouring rain to clean a downspout out.
Robin
nizmut Offline
Images: 0
Postby nizmut » Mon May 22, 2017 10:12 pm
What was I thinking :think:
Robin
nizmut Offline
Images: 0
Postby nizmut » Mon May 22, 2017 10:19 pm
I'll be out of shop space soon.
Robin
nizmut Offline
Images: 0
Return to Show us Your Patrol!
