Postby plateaucal » Thu May 31, 2018 3:04 pm
I am blushing, however I do echo your sentiments regarding the folks on the forum and the thrill of the chase.
plateaucal Offline
Has thanked: 140 times
Been thanked: 409 times
Postby L60Boerne » Sat Jun 02, 2018 9:17 am
Greetings Patrol and Auto Archeologists Worldwide,
Plateaucal, a veteran High Altitude Patrollee reinforced my thoughts about taking Command and Control Vehicle 6 Cyclops over the top of the mountains around here on the jeep trails. First, CCV6C will certainly do it mechanically, but the acute angles of attack, combined with one lane roads with shoulder drop offs that would scare the dead are concerning...why? Because in order to ensure the motor is in the right gear to maintain power at all times, I would need to be in my lowest possible gear most of the time. For some reason I can't downshift without serious grinding. I have tried single, double and triple clutching but regardless.... down shifting requires force with horrible noises from the place where everything lands after it slides off the seat. That means a slightly faster than walking pace. Given the popularity of these trails I would hold up several hundred vehicles. However, it doesn't stop us from travelling the same type of trails in the lesser known places. Today we will go up into headwaters of the Big Blue Basin. Pictures to follow.
Patrolling in Sirene Places,
63 Soft Top - For Sale (CCV5)
65 No Top - Presidio Patrol
66 Hard Top - CCV6
L60Boerne Offline
Images: 0
Has thanked: 4 times
Been thanked: 993 times
Postby Esteban » Sat Jun 02, 2018 12:32 pm
What if you try driving those stretches with the transfer case in Low. When in low gear, 2nd is a little more powerful than 1st in high, and 3rd in low faster. In that case you can down shift with the help of the synchros.
The double clutching, once mastered is great, and becomes second nature.
Has thanked: 3283 times
Been thanked: 943 times
Postby RiverPatrol » Sat Jun 02, 2018 12:33 pm
First gear is not synchronized (no synchros), so unless you are at or nearly at a complete stop, it will grind when downshifting into first gear. That's just the way it is.
Images: 768
Has thanked: 4467 times
Been thanked: 1360 times
Postby plateaucal » Sat Jun 02, 2018 4:56 pm
Excellent advice Esteban. And bring your fly pole and your Texan swatter with you, David.
plateaucal Offline
Postby plateaucal » Sat Jun 02, 2018 5:27 pm
My concern about the Patrol on the variety of trails in this area is oriented around carburation, no synchro first and braking. There are all levels of trails but even simple but steep trails could get interesting. Engineer Pass is almost 13,000.It's generally an easy but spectacular drive. However some of the grades are steep and the roads are narrow with BIG dropoffs. There are issues with loss of power at altitude, running rich due to jetting and fuel bowl level. Stalling on a simple but steep uphill grade could be ugly, especially with drum brakes. So my advice to David is to experiment at altitude, easier grades, and maybe practice a dead stop on a steep grade with not too much exposure.
Any thoughts would be useful because this guy is serious. He is going Patrolling.
plateaucal Offline
Postby L60Boerne » Sat Jun 02, 2018 6:15 pm
Greetings once again,
Funny things happened around a vintage Patrol.
At 8:30 am was mobbed by a group while I was trying to eat breakfast in town. Had to open the hood and go through the whole program while my biscuits and sausage gravy got colder than witch's nose.
Then our plan to go up to Big Blue Basin was uneventful.....until stumbled into a wedding on Alpine Plateau, literally 50 miles from nowhere. The Patrol was quickly commandeered by the wedding photographer as a prop.
The 14,800 ft peak in the distance was scales by yours truely in less than 5 hours...side note and yes I'm still patting my own back.
Just a day in the life.
Patrolling with passion,
I'm sure the pics aren't in sequence, sorry.
66 Hard Top - CCV6
L60Boerne Offline
Images: 0
Postby L60Boerne » Sat Jun 02, 2018 6:33 pm
Few more pics.
66 Hard Top - CCV6
L60Boerne Offline
Images: 0
Postby plateaucal » Sat Jun 02, 2018 7:38 pm
I am guessing, but maybe your wife is sold on the concept. Good times.
plateaucal Offline
Postby plateaucal » Sat Jun 02, 2018 7:39 pm
Hunting trip? Unit 65. Next year? I'll show you around and we can hike as high as our lungs and sensibility allow.
plateaucal Offline
Postby Esteban » Sat Jun 02, 2018 7:44 pm
David.
Congratulations on all that you've done. I'm sure everyone here is following your trip and eagerly waiting for the next installment. You definitely have a special way of conveying your journey, even your mishaps.
The Patrol looks fantastic!
And I'm sure this wedding that you run into, will last at least as long as your Patrol, or any Patrol for that matter.
I went to my honeymoon in my Patrol, and my youngest daughter got married in it. The images today of the wedding, just look surreal.
Postby plateaucal » Sat Jun 02, 2018 7:48 pm
That looks like Uncompahgre Peak. About 14,309. Named after the local Ute Indian tribe. Did you scale that today?
plateaucal Offline
Postby L60Boerne » Sat Jun 02, 2018 8:01 pm
Thanks to all, you all know this Patrol, as well as Presidio Patrol, are products of this forum. Finally my wife is getting more confident as I demonstrate how the gears can be used to limit dangerous situations. I'm not daredevil.
Unit 65 is absolutely in our future. Thank you for the encouragement. However, I got a really bad case of frostbite hunting bears up around the arctic circle a few years ago and the cold isn't as much fun as it used to be but I'm game. I just need to get passed Zim 2019, very warm there, then I'll refocus on NA, that is my plan. I look forward to alot of good times around here.
Patrolling with a smile, and a happy wife...for a change.
66 Hard Top - CCV6
L60Boerne Offline
Images: 0
Postby RiverPatrol » Sun Jun 03, 2018 11:52 am
Most excellent! So proud that you have persevered and attained your goal. I know the Patrol is completely capable of anything you decide to put it through. I have personal experience on treacherous trials finessing the gears and potential stalling. You just prepare for it and deal with it. The remote throttle comes in very handy in some of those situations. Excellent pictures, it looks like a great trip. Thank you for sharing.
Regarding the rich running: did you ever address the carb insulator to verify that the notch was present? viewtopic.php?f=4&t=5004&p=39403&hilit=insulator#p39403
Images: 768
Postby L60Boerne » Tue Jun 05, 2018 7:55 pm
A few more of CCV6 w/cyclops.
66 Hard Top - CCV6
L60Boerne Offline
Images: 0
Return to Projects
Users browsing this forum: moore_rb and 3 guests
