Postby mad4hws » Mon Jun 20, 2016 7:34 pm
At first glance, the wiring in the minion looks to be in really good shape.
5249
mad4hws Offline
Images: 243
Has thanked: 132 times
Been thanked: 240 times
Postby mad4hws » Mon Jun 20, 2016 7:38 pm
Fuse Block
5257
mad4hws Offline
Images: 243
Postby mad4hws » Mon Jun 20, 2016 7:42 pm
Upon closer inspection, this looks to be either an unfinished low budget project.
At a minimum, it needs connectors and not electrical tape:
5253
There are dead ends everywhere:
5251
5254
It seems like every wire is either yellow with an orange stripe, or red with a white stripe.. hmmmmm. I'm cheap, but this makes trouble shooting nearly impossible.
So, After looking at this, I decided that the minion deserves better.
mad4hws Offline
Images: 243
Postby mad4hws » Mon Jun 20, 2016 7:46 pm
I decided to go with the painless performance kit (10102).
5255
What's really cool about this kit is that the wiring has the intended component laser printed directly onto the wiring. Seems pretty painless to me!
5256
I got some extra connectors and also decided to replace the engine grounding strap after inspecting the old one:
5247
mad4hws Offline
Images: 243
Postby mad4hws » Mon Jun 20, 2016 7:49 pm
This is going to take some time to do, but looks like it's pretty do-able for an accountant with virtually no mechanical/electrical skills. This past weekend, a couple of the minions and I fabricated a bracket for under the dash to hold the fuse block. I want it out of the engine compartment and didn't want to use up the glove box. I think there will be enough space, but we'll see how it goes.
Stay tuned for more updates.
mad4hws Offline
Images: 243
Postby RiverPatrol » Mon Jun 20, 2016 9:02 pm
Great project. Definitely keep us posted.
Images: 768
Has thanked: 4468 times
Been thanked: 1360 times
Postby zed » Mon Jun 20, 2016 9:42 pm
mad4hws wrote:This is going to take some time to do, but looks like it's pretty do-able for an accountant with virtually no mechanical/electrical skills. This past weekend, a couple of the minions and I fabricated a bracket for under the dash to hold the fuse block. I want it out of the engine compartment and didn't want to use up the glove box. I think there will be enough space, but we'll see how it goes.
Uh-oh, another accountant on the Forum, I better get back to the Patrol project...we gotta show them engineers and mechanics how us pencil pusher can complete an assignment on time and under budget!
Keith :lol:
zed Offline
Images: 119
Has thanked: 33 times
Been thanked: 347 times
Postby mad4hws » Mon Jun 20, 2016 10:08 pm
Keith :lol:
I'm completely out of my element on this and not afraid to admit it. I'll gladly accept any advice or criticisms that my mechanic or engineering brethren are willing and able to share! Seriously, this is a great forum and i wouldn't dream of tackling this project without it.
I was planning on starting by labeling everything on the "as is" minion before dismantling. As I look at it though, the standard Painless kit actually looks pretty painless and includes most everything i will need - and even extra. I don't have a radio, air conditioning, electric fan, 3rd brake light just to name a few... Oh, and the heater too... Although I really need to find one of those before winter sets in. Anyway, I guess I better label the existing harness before ripping out, but don't know how much I'll actually rely upon it as it was patched together over time and I actually trust the painless diagram/instruction better. I'm pretty sure an engineer had something to do with that (if it turns out to be an accountant, I'll be asking for my money back!).
Ordering up a few things I think I will need along the way. New connectors from Vintage. Extra wiring, primarily for grounding (not included in the painless kit) and replacement grommets.
mad4hws Offline
Images: 243
Postby ckhorne » Tue Jun 21, 2016 8:35 am
Probably a good call on replacing that wiring - it's in pretty rough shape!
Have a look at my thread, where I replaced all the wiring in my Patrol - my posts about wiring starts here: http://www.60patrol.com/forum/viewtopic ... 718#p22718
I went with the same Painless harness, and it worked out well. I really recommend the braided sleeves with heat shrink around the ends. Also- don't bother labelling everything you have now - I did that as well, and it ended up being easier to just remove all the existing wiring and follow the painless harness's labelling / diagram. re/bracket- I was able to use the existing bracket and mount in the glove box, but if you want to mount in the engine bay, then you'll want a different bracket. Definitely put the fuse block where you want it first (just don't screw it down) and start running wires. Make *sure* you have a good ground everywhere you go. I added a few grounding straps between panels or other parts around the truck as I went because I kept running into grounding issues. A good tester helps immensely here. Use waterproof connectors for anything serviceable - turn lights, anything in the engine bay, etc.
Feel free to ask questions here - it's been 2 years, but I'm happy to help!
ckhorne Offline
Has thanked: 49 times
Been thanked: 138 times
Postby mad4hws » Tue Jun 21, 2016 11:53 am
thanks CKHorne,
what a great build thread you had. It's sure to be referred to often. I will likely run into some issues, so I appreciate your willingness to reach into your memory banks. Painless also makes braid in various sizes. I ordered that kit too - I can't have this looking a mess when it's all done. I ordered a bunch of extra water proof connectors along with the Vintage connectors someone else on the forum found (have to give credit later). I also ordered a good supply of ground wire, rated to withstand 275 Degrees F in 12 an 14 gauge. Before I rip it out, I want to make sure I have everything I will need to complete the task so I can get the Patrol back on the road quickly.
mad4hws Offline
Images: 243
Postby mad4hws » Wed Jun 22, 2016 9:28 pm
Not much of an update. Busy day at the salt mine... and then there was a 12 year old birthday party for one of the minons...
I was thinking about my horn. The horn assembly is not currently working. The former owners jerry rigged a button underneath the dash, so I do have a horn. I'd really like the ability to lay into the center of my steering wheel and not have to fumble around for the button on the dash though when someone cuts me off. I haven't attempted to tear this apart, is there anything big that I am missing? Looked at the diagrams and it seems I'm missing a spring at a minimum.
5263
mad4hws Offline
Images: 243
Postby RiverPatrol » Wed Jun 22, 2016 10:13 pm
Besides the spring, there should be some small pieces at each of the 3 screws. Here is a post about them: http://www.60patrol.com/forum/viewtopic.php?f=24&t=4267&p=33281&hilit=horn#p33281 . They are put in place with o'rings around them, as I recall.
Images: 768
Postby mad4hws » Thu Jun 23, 2016 9:20 pm
Today's update. ripped the old harness out.
5270
Engine compartment looks mucho better.
52735272
Also got my vintage plug assortment in the mail. unbelievably accurate - plug and play
52665265
The crimpers that come with the kit are substantial and deep with ratcheting action. I have no doubt will do a fantastic job on the connections.
5264
mad4hws Offline
Images: 243
Postby ckhorne » Fri Jun 24, 2016 7:57 am
Looking good - now the fun begins! :)
One other note - I borrowed one of these from a friend and found it to be really useful: https://www.amazon.com/Power-Probe-319F ... B000KPU8MK
I've got a bit of a background in electronics and have a number of multimeters and other equipment, but nothing did what this one does- you attach the clips to your battery, and then you can test for +12v or ground, or you can push a button and send +12v or connect ground to the tip. Very useful in diagnosing as you go. I'm sure there are cheaper versions out there - they all do the same thing.
ckhorne Offline
Postby mad4hws » Mon Jun 27, 2016 9:17 am
Indeed the fun is beginning. I started to put in the new harness, beginning with mounting the new fuse block. We took a break and I participated in a pick-up soccer game with #2 Minion and his friends. I ended up in the ER after my knee bent in a direction it was not intended to go. I shouldn't be playing contact sports at my age I suppose. I have an appointment with the orthopedic later today - please keep your fingers crossed that the 'pop' i heard wasn't something too serious. Hobbling around on crutches is going to make this task even more challenging than it already was. Good thing I have lots of helpers. More updates later.
p.s. Thanks CK for the advise and the tool recommendation. I need every advantage I can get.
mad4hws Offline
Images: 243
Next
Return to Projects
