my 1967 patina project build
Postby rdarnell » Fri Apr 05, 2019 7:37 pm
Old Ford blue and Cummins tan should make a nice combo. Looking at my transfer case I could not find any hint of blue. But it was not seafoam green either, it looks more like a tan color. On the trans I did find a small amount of blue and the top cover appears to have had black on it.
6267
6266
6268
rdarnell Offline
Images: 270
Has thanked: 146 times
Been thanked: 281 times
Postby Edgar » Fri Apr 05, 2019 10:06 pm
what brand of paint did you use?
Edgar Offline
Images: 69
Has thanked: 189 times
Been thanked: 83 times
Postby rdarnell » Sat Apr 06, 2019 7:41 am
Duplicolor engine paint. From napa, O'Reilly's, or meijers. There are three different colors of Ford blue, napa was the only one that carried the old Ford blue.
rdarnell Offline
Images: 270
Postby rdarnell » Sun Apr 07, 2019 5:57 pm
Got transfer case back together. Replaced 3 bearings in it the rear bearing is 6208NR and front of case is 6208. The third bearing in up front in the nose cone, it is 6307NR.
6277
I also replaced the seals in both trans and TC. I found recommendations on the forums. The pinion seals a quite tight but the other two seem to work fine.
6269
6270
6271
I have everything back together except for the output seals, I am going to see if I can find a better fitting seal.
6275
6274
rdarnell Offline
Images: 270
Postby Esteban » Sun Apr 07, 2019 6:30 pm
Congratulations and thanks for posting these! Looks great!
Did you check the conditions of caged needle bearings inside the big gear (low/high), and also the axle that they run onto?
Years ago I had problems with that axle and had to replace it. I'm worried now on sourcing the caged needle bearings.
Has thanked: 3664 times
Been thanked: 1003 times
Postby rdarnell » Sun Apr 07, 2019 8:18 pm
All of the needle bearings in the transfer case looked good. The roller bearings were also good but since I already bought them I decided to change them out.
Went back and re-read some posts and found where rmp&o posted a link. It still works so I ordered 4 of the correct pinion seals.... now we wait.
https://www.amayama.com/en/part/nissan/381
rdarnell Offline
Images: 270
Postby rdarnell » Wed Apr 24, 2019 7:42 pm
Well the UD seals from the http://www.amayama.com site are the correct seals for the pinions and the outputs on the transfer case. They go in perfectly and fit the yokes perfect. Thank you RMP&O for posting that link several years ago.
6279
6280
rdarnell Offline
Images: 270
Postby rdarnell » Sun Apr 28, 2019 8:38 pm
Took apart the rear driveshaft, cleaned and painted it. While waiting for the paint to dry I cleaned and inspected the universal joints. Everything looked good so I was able to reuse them. I read in so other forums that there is not a direct replacement part. I took a look on the amayama website using the nissan part number and a part for UD came up but it was $98 each.
6283
6284
rdarnell Offline
Images: 270
Postby curlrider11 » Sun Apr 28, 2019 10:24 pm
Hey nice driveshaft and u-joint resto :-) I'm getting deja vu. just be careful not to damage the lip of the caps when hammering back together I actually bent mine pretty good by misaligning and had to bend it back a bit before reassembling. Cheers
"bad, bad," says the buyer, but when he goes away, then he boasts Pr. 20:14
curlrider11 Offline
Has thanked: 23 times
Been thanked: 186 times
Postby rdarnell » Mon Apr 29, 2019 9:40 am
I am using a balljoint/universal joint tool to take apart and reassemble. those angled sides on the yokes are not a bit helpful thought!
6285
rdarnell Offline
Images: 270
Postby curlrider11 » Mon Apr 29, 2019 4:02 pm
Nice! Wish I had used one
curlrider11 Offline
Postby rdarnell » Tue May 07, 2019 2:36 pm
Decided to start on disassembly of the other driveshaft last night and it definitely looks like it might have been out before... cannot imagine the factory put the yokes out of time!
6290
rdarnell Offline
Images: 270
Postby rdarnell » Wed May 08, 2019 7:39 pm
Finished up disassembling the driveshaft. Apparently it has taken some hard hits in the past. One end came apart pretty easy and the other end the 2 caps in the spline end of the yoke took about 30 minutes of pressing and de-burring and then repeating several times. The hole must not have been perfectly round, I wound up shaving some of the yoke while pressing. Fortunately I have a spare that came apart nicely.
6294
6293
I have accumulated quite a nice collection of vintage dirt/grease from the 4 universal joints!
rdarnell Offline
Images: 270
Postby rdarnell » Mon May 20, 2019 11:57 am
Took out the axle this weekend, it was surprisingly easy. Got started on the disassembly and cleaning.
6308
6309
rdarnell Offline
Images: 270
Postby rdarnell » Mon May 20, 2019 7:38 pm
For those interested in the weights... the axle housing with the differential comes in at 130 pounds. On a side note the transfer case is 120 pounds, transmission is 75 pounds and the PTO is 25 pounds.6310
rdarnell Offline
Images: 270
Return to Projects
