1969 Patrol, Take 2: Action!
Postby yitzac1990 » Sat Oct 26, 2019 9:04 am
Well I made a rookie move....I forgot to put my gas cap back on after filling up. Does anyone have a spare gas cap for a 69 patrol?!?
yitzac1990 Offline
Has thanked: 30 times
Been thanked: 147 times
Postby Esteban » Sat Oct 26, 2019 11:52 am
I have this reference in my notes:
Gates 31722 – no lock
Probably another member posted this cap at some point.
Has thanked: 3056 times
Been thanked: 918 times
Postby yitzac1990 » Sat Oct 26, 2019 1:43 pm
Thanks! I was actually looking around and found one locally that fit great. Stant 10632. Found at Oreillys for $6
yitzac1990 Offline
Postby yitzac1990 » Wed Oct 30, 2019 8:13 am
I recently ordered a roll of rubber seal to re-seal my doors. I only ordered one roll, to make sure it fit good, and it wound up working out pretty great! it is a "D-shape" seal. Here is the link where I ordered it:
https://www.amazon.com/dp/B07V2N1N6L/?c ... _lig_dp_it
I sealed the bottom of the front doors (there was a huge gap....why did nissan design it like that??), and all around the passenger side door, then ran out after doing one part of the driver side door rear. I ordered another roll and will hopefully have enough for the rest of the driver door, and the rear doors as well. Will post pics soon.
I also plan on ordering some sound deadening/insulation for the engine bay and front cab area. Hopefully make listening to the radio a bit better!
yitzac1990 Offline
Postby yitzac1990 » Mon Nov 11, 2019 1:19 pm
Looking for an OEM handbrake lever assembly. basically these 2 parts pictured here:
the lever itself, and the toothed piece that the lever rotates around. I got rid of mine when I sold my complete motorset :(
yitzac1990 Offline
Postby moore_rb » Tue Nov 12, 2019 12:23 pm
yitzac1990 wrote:
moore_rb wrote:
I don't think 3/8" studs will be up to the task of handling the leverage that a steering arm would place on them (especially with bigger, heavier tires)
returning to this...my original plan was to replace the OEM studs with a longer length stud, attach a high steer arm, and then a nut on each stud. what if I replaced the studs/nuts with long, Grade 8 bolts instead? Bolt all the way through the steering arm, king pin, shims, into the knuckle. Do you think that would hold better? I could also weld another support piece to the knuckle and bolt the arm through that as well?
Nope- you have to use grade 8 studs- Twice as much clamping power as an equivalent sized bolt
I found the steering drag link that was used on my lifted green Patrol, and I noticed that it looks like it was heated and bent to clear the passenger side spring more easily... I have no use for it, so if you want it badly enough to pay for the shipping, you can have it.... That could at least buy you some time while you design a more robust solution.
moore_rb Offline
Images: 68
Has thanked: 597 times
Been thanked: 947 times
Postby yitzac1990 » Tue Nov 12, 2019 11:06 pm
I appreciate it! But my current setup, although a bit janky, seems to be working fine for now actually haha
yitzac1990 Offline
Postby yitzac1990 » Fri Nov 15, 2019 1:22 pm
So I ordered some new steering linkage boots from new-datsun-parts and put them on last night. Has anyone else ordered these from their website? The new part is different from the OEM part, with the holes off a bit. Take a look at the pics:
You can see, with the boots oriented the same way, the holes on the new boot are lower. I went ahead and installed them anyways, but just want to share my experience with these parts. On the plastic bag that the boots were in, was a part number "P127" I think, if that means anything
yitzac1990 Offline
Postby Esteban » Fri Nov 15, 2019 1:29 pm
Thanks for pointing this out. Maybe they are for models on the wrong side of the road! Seriously.
Better than using the ones for the FJ40 which are smaller in diameter.
Don’t forget to show a picture once installed.
Postby yitzac1990 » Fri Nov 15, 2019 1:46 pm
good point, i didnt think of that. But I would imagine that instead of designing a whole new drag link and end boots, Nissan would take an existing drag link and just turn it around to use on LHD vehicles. Which would result in still the same parts being used (drag link and boots).
Ill try to get an installed pic this weekend.
yitzac1990 Offline
Postby Esteban » Fri Nov 15, 2019 2:01 pm
yitzac1990 wrote:good point, i didnt think of that. But I would imagine that instead of designing a whole new drag link and end boots, Nissan would take an existing drag link and just turn it around to use on LHD vehicles. Which would result in still the same parts being used (drag link and boots).
After your comment I went to check the parts manuals of both LHD and RHD, and in fact they are different! :roll:
LHD 48522-44200
RHD 48522-44000
Postby yitzac1990 » Fri Nov 15, 2019 2:46 pm
ahh, I see! that may explain it. I searched your part numbers there and found something interesting....
http://www.autoletparts.com/Total36.html
This parts shop based in Thailand actually has brand new Patrol G60 parts! With that dust boot being one of them! no prices though, I wonder how their parts prices compare to other prices closer to or in the US...
yitzac1990 Offline
Postby RiverPatrol » Sat Nov 16, 2019 10:52 am
Cool site! perusing the variety of parts they have available, I'd say they were a supply of Jonga parts. Interesting.
Images: 766
Has thanked: 4199 times
Been thanked: 1304 times
Postby yitzac1990 » Mon Nov 18, 2019 5:57 pm
so I messaged new-datsun-parts and sent them those pictures of the boot. they said they are going to check on the part numbers with their supplier in Japan. Maybe it is a possibility that that boot was modeled after a RHD boot, and the LHD is opposite...Ill see if I hear anything back.
yitzac1990 Offline
Postby Peter60 » Tue Nov 19, 2019 9:17 pm
Have a look at this post - Well do a search on this forum for the post by moore_rb
Search for "Toyota 45457".
Peter60 Offline
Has thanked: 118 times
Been thanked: 174 times
Return to Projects
Users browsing this forum: Daner and 1 guest
