1969 Patrol, Take 2: Action!
Postby Esteban » Tue Jun 11, 2019 2:11 pm
Excellent work! :clap: :clap: :clap: Thanks for taking the time to do it... and so fast! :shock:
yitzac1990 wrote:so if I wanted to leave the hazard switch out, could I still run the brake switch integrated with the turn signal switch? Based on the wiring schematic I found on this forum, I came up with this diagram specifically for the turn signal circuit (attached).
Also, if my color call-outs and numbers on the hazard switch could be double-checked and confirmed I would appreciate it. the diagram I downloaded was a bit grainy!
Patrols before 1997 didn't come with the hazard, and also some later models for other markets (I had a 74 without hazards). Basically is an add-on, so you can take it out of the system and everything will work.
Comparing your diagram with one that I had downloaded from a couple of years ago, it looks correct, colors and terminal numbers... So rather than checking the correctness of yours, I was learning in the process.
At some point in your progress these diagrams will need to me moved to the electrical section in the forum. :clap: :clap: :clap:
Has thanked: 2866 times
Been thanked: 888 times
Postby yitzac1990 » Wed Jun 12, 2019 10:17 am
Esteban wrote:At some point in your progress these diagrams will need to me moved to the electrical section in the forum. :clap: :clap: :clap:
Thank you very much! I actually kind of like doing wiring diagrams. The first time I ever did one was on just the last project I worked on and it made everything so much easier.
The wiring diagram that I am making for my patrol will not be an OEM diagram "remake", more like a custom diagram to suit my needs for my patrol. But I did want to make the turn signal diagram matching the OEM diagram to make sure I wire it up right. Feel free to grab the turn signal wiring above and post it wherever it needs to go.
I think I will keep the hazard switch since I have the colors/numbers correct....just hope my gf can help me with the colors since i'm color blind :lol:
yitzac1990 Offline
Has thanked: 26 times
Been thanked: 133 times
Postby Esteban » Wed Jun 12, 2019 10:33 am
yitzac1990 wrote:...I think I will keep the hazard switch since I have the colors/numbers correct....just hope my gf can help me with the colors since i'm color blind :lol:
I'm color blind too!! :lol: or color vision deficiency as more and more is known. Always use my wife's help with these projects. For a number of years was a good excuse for not buying her any clothes..
Postby yitzac1990 » Fri Jun 14, 2019 7:18 am
since my patrol didnt come with a gas pedal, for whatever reason, I did some cutting and welding and put on a Nissan 240sx gas pedal. I also added in a throttle cable from a 240sx as well.
yitzac1990 Offline
Postby yitzac1990 » Tue Jun 18, 2019 5:01 pm
so today I was able to get the engine and transfer case pressure washed. I am going to be replacing all the "easy" gaskets on the engine, and rebuilding the tcase and trans. getting closer every day. I have a stockpile of parts in my shop just waiting to go on!
I also "refurbished" the OEM control switches (headlights, wiper motor, hazard, blower motor) and they all seem to work just fine! I am only missing one knob, for the wiper motor. I found a knob on amazon that I think should work just fine, I will just need to drill a small hole for a set screw. it is a J.W. Winco GN419 series knob, part number 6NB59. Here is a link to it on Amazon:
https://smile.amazon.com/dp/B00PUDAQB0/ ... _lig_dp_it
it has an internal M6 thread, which is what the wiper motor control is, so it should thread right on.
I also got the fuel tank "converted" for EFI, with a new 3/8" fuel feed fitting, 5/16" fuel return fitting, brand new fuel level sender, and cleaned out the rust/crud as best I could. Installed the fuel pump as well, which is an external 255lph pump and will be plenty for the chevy engine.
yitzac1990 Offline
Postby MadTripper » Wed Jun 19, 2019 6:37 am
Nice work and I'm anxious to see the outcome!
Tripper
MadTripper Offline
Images: 47
Has thanked: 41 times
Been thanked: 79 times
Postby yitzac1990 » Thu Jun 20, 2019 11:35 am
Here I have attached the wiring diagram I have made so far. completely new wiring all throughout the vehicle. In general, the line thickness represents the wire gauge. Let me know what you think!
- I know the brake switch circuit is wrong, since it will be integrated into the turn signal and hazard switches (2nd page), but I wanted to put something in there representing a brake still.
- I currently have the ECU wiring harness in a standalone configuration, therefore all it needs is a single power wire to make it all work.
- I will have to get the ECU tuned to remove VATS (vehicle anti theft system), and when I do that I can have one of the pins "turned on" as a fan controller, so I will be doing that for the fan relay signal.
yitzac1990 Offline
Postby yitzac1990 » Sat Jun 22, 2019 8:02 pm
Here is the current status: the engine received all new gaskets, new timing kit, new oil pump, new water pump, and a general cleanup of at least most of the gunk that was all over it. and the transmission rebuild has started. I had to run out and get a bearing puller kit, so the transmission progress will continue tomorrow. Reading the instructions from Novak, I think it might actually be easier than I thought, but this is the first time I have ever rebuilt a trans, so wish me luck!!
yitzac1990 Offline
Postby Edgar » Mon Jun 24, 2019 7:47 am
Wishing you luck!! Looks like you are on the right track. :pray: :pray:
Edgar Offline
Images: 55
Has thanked: 117 times
Been thanked: 53 times
Postby yitzac1990 » Tue Jun 25, 2019 11:54 am
Here is a slightly updated PDF of the wiring. I believe this is the finished wiring diagram, for my patrol at least. I forgot the ECU has a couple more power inputs needed, and the gauges will all have power together as well. The electronic speed sender will be included with the gauge wiring, so its not pictured, and again the brake switch will be switched out appropriately for the turn signal and hazard wiring seen on page 2.
yitzac1990 Offline
Postby yitzac1990 » Mon Jul 01, 2019 5:29 pm
well I have been waiting on the transmission rebuild to continue with progress on the patrol build. I got the new main shaft built last night with the help of a friend:
But when I went to reassemble the transmission, something seems not right. Is there anyone on here that happens to know a lot about SM465 transmissions and/or how to rebuild them??
https://www.youtube.com/watch?v=o8r_teugvjU
yitzac1990 Offline
Postby seth1001 » Mon Jul 01, 2019 10:20 pm
While we're on the subject of the transmission and transfer case, I have a question for you. According to a recent conversation I had with a dude at Novak and Advance Adapters, the Dana 18 is really only good for transmission RPM's equating to around 55-60 mph before it vibrates bad and runs the risk of falling apart. Have you read anything about this or planned any changes to your T/C to mitigate this risk? Or with that 4-speed tranny are you just not planning to go any faster anyway?
seth1001 Offline
Has thanked: 3 times
Been thanked: 25 times
Postby yitzac1990 » Tue Jul 02, 2019 9:46 pm
I had not read anything like that, i appreciate you bringing that to my attention. with that said, I dont plan on over revving this thing just so I can do 70 on the highway. However, i do plan on eventually getting an overdrive unit for the TC which will give me a "5th" gear, at 0.75 ratio. this coupled with some big tires will allow me to keep the RPMs relatively low and still keep up on the highway. Im not sure if I want to splurge on the overdrive before I install everything, or later down the line. I am kind of thinking later on down the line after the patrol is up and running.
yitzac1990 Offline
Postby yitzac1990 » Tue Jul 02, 2019 9:49 pm
another update: I got the transmission figured out! I took it all apart again to make sure everything was installed correctly, and this time when putting it back I was able to seat the rear main bearing all the way in, which pulled everything together nicely.
Here it is all buttoned up with new seals/gaskets and the Novak TC adapter on it:
I was also about to get my clutch and flywheel mated to the engine, when I realized the flywheel I had was a completely different bolt pattern and crank center bore than what I needed. so i wasnt able to get to that, but I have already ordered the correct flywheel for the job.
yitzac1990 Offline
Postby Esteban » Wed Jul 03, 2019 7:08 am
Excellent! :clap: :clap: :clap:
Glad you figured out. We can even sense your satisfaction.
Very interesting to follow your thread.
Return to Projects
cron
