1969 Patrol, Take 2: Action!
Postby yitzac1990 » Wed Aug 14, 2019 8:28 am
ive also started on designing my front caliper brackets!
yitzac1990 Offline
Has thanked: 30 times
Been thanked: 153 times
Postby yitzac1990 » Thu Aug 15, 2019 7:50 am
The other side of the front axle is done! The rear should be way easier, but its vacation time now for a week
yitzac1990 Offline
Postby Esteban » Thu Aug 15, 2019 8:01 am
Great progress!
Any special reason why you added the extra leaf in the spring? I like the fact of the curved geometry with less friction contact to the rest. Will be very interesting to see how it perform.
Weight wise, how is the Chevy/tranny power train comparing with the P engine one?
Has thanked: 3283 times
Been thanked: 943 times
Postby mdawg4x4 » Thu Aug 15, 2019 11:53 am
yitzac1990 wrote:The other side of the front axle is done! The rear should be way easier, but its vacation time now for a week
Spring over conversion? Any concern for drive line vibrations to to drive shaft angles?
mdawg4x4 Offline
Has thanked: 329 times
Been thanked: 277 times
Postby yitzac1990 » Fri Aug 16, 2019 6:19 am
Esteban wrote:Great progress!
That extra spring was already on the patrol when I got it. I'm guessing the spring pack was sagging a bit so previous owner added a helper? And I have wondered about the weight question...honestly I think the v8 weighs less or the same as the P engine.
yitzac1990 Offline
Postby yitzac1990 » Fri Aug 16, 2019 6:22 am
mdawg4x4 wrote:Spring over conversion? Any concern for drive line vibrations to to drive shaft angles?
I'm basically just gonna send it and see what happens lol. I had a Suzuki samurai with a spoa swap and unbalanced and crooked driveshafts (previous owner) and it definitely shook a lot, but it was just a toy, like the patrol will be. Once I get everything together and on the ground I will check angles and all that, and add shims if needed.
yitzac1990 Offline
Postby mdawg4x4 » Fri Aug 16, 2019 12:02 pm
And it's not like you are going to be doing 75 down the interstate every day.
mdawg4x4 Offline
Postby yitzac1990 » Fri Aug 23, 2019 7:09 am
back from vacation, and back to work. I took some measurements of the front spindle, hub, and caliper to create a 3d model to help with bracket creation:
I also put the front axle back on the patrol last night! big difference Id say!
yitzac1990 Offline
Postby moore_rb » Fri Aug 23, 2019 9:59 am
yitzac1990 wrote:honestly I think the v8 weighs less or the same as the P engine.
The P engine (and the chevy I6) actually weigh about 50% more than a SBC with iron heads.
Nissan 6: 640 pounds (Chevy inline 6 is just a few pounds lighter- about 630)
Iron head Chevy small block: 430
aluminum head Chevy: 400
regarding the springs- the perfect neutral stance for a SOA conversion is for the springs to be horizontal (zero arch) on flat ground, and for the spring rate to allow equal amounts of compression and droop travel. Any positive arch on the front springs at final ride height increases droop travel, and decreases compression travel, which results in increased likelihood of bump steer.
and this geometry should really be set with your final powertrain choice all mocked up in the vehicle
moore_rb Offline
Images: 68
Has thanked: 677 times
Been thanked: 1069 times
Postby yitzac1990 » Fri Aug 23, 2019 1:16 pm
moore_rb wrote:and this geometry should really be set with your final powertrain choice all mocked up in the vehicle
yes sir, the whole drivetrain (engine, trans, TC) is in and set already.
yitzac1990 Offline
Postby yitzac1990 » Sun Aug 25, 2019 8:23 pm
the rear SPOA swap is done. I had the axle out, welded, and back in in about an hour, much easier than the front. The axle shafts are currently out because the hubs need to be turned down a bit to fit the rear rotors for the disc brake swap. Also, does anyone have or know where I can get another rear axle nut lock washer? one of mine is a bit chewed up!
yitzac1990 Offline
Postby yitzac1990 » Mon Aug 26, 2019 9:00 am
the nissan patrol community is great...just ordered new parts for the rear: axle shaft nuts, axle shaft lock washers, inner and outer seals.
yitzac1990 Offline
Postby yitzac1990 » Tue Aug 27, 2019 10:08 pm
i got the hard brake lines in tonight, from brake master cylinder to the frame rails. ordered some fittings and SS braided line to go to the axles. then of course have to finish the brake swap to finish off the rest of the line. Good progress though! I cant wait until I get to drive this thing.
One thing I find really weird about the Patrol, is that there is actually a lot of SAE fittings/hardware on this thing...
yitzac1990 Offline
Postby Esteban » Wed Aug 28, 2019 7:38 am
yitzac1990 wrote:...One thing I find really weird about the Patrol, is that there is actually a lot of SAE fittings/hardware on this thing...
That's one of the beauties of the Patrol. Everything is SAE in Patrols up to ~1977, when they switched to metric (a weird change for a few years of remaining production). There's probably a couple of other Datsun vehicles with SAE, since they built Austins in Japan that ended up being of better quality than the British ones.
The engine on the Patrol has an American soul. It's based on a 1938 Graham-Paige engine (flat) that later on in the 50s was modified by an American engineer into the overhead cam one that we have in ours.
Postby Flaggoni » Wed Aug 28, 2019 12:40 pm
My 64 Datsun pickup (model L320) also is 99% SAE.
The 1200 cc engine also shares a few Austin-like parts.
Our Patrols do have a few metric fasteners, mostly on electrical accessories.
Mild Bill
Flaggoni Offline
Has thanked: 193 times
Been thanked: 211 times
Return to Projects
