Straight 6 Ford to Patrol Tranny
Postby 66AzPatrol » Sat Jul 20, 2019 12:21 am
There is a light colored adapter between Ford motor and stock tranny & I think clutch plate isn't flush. Acceleration isn't matching motors performance.
Any company names that make the adapter?
Have some tranny chatter backing up (sometimes), this weekend crawling under to see if mounts loose.
66AzPatrol Offline
Images: 0
Has thanked: 7 times
Been thanked: 17 times
Postby seth1001 » Fri Aug 09, 2019 3:14 pm
66AzPatrol wrote:There is a light colored adapter between Ford motor and stock tranny & I think clutch plate isn't flush. Acceleration isn't matching motors performance.
It must be a custom job. There's no company that ever made any adapters for the G60 tranny to mount to different engines.
seth1001 Offline
Has thanked: 3 times
Been thanked: 25 times
Postby limited slip » Mon Dec 23, 2019 5:51 am
That is incorrect. At least in australia.
Both dellows and castlemaine rod shop made adaptors from 3spd crash box, 4speed mq patrol and 5speed mq/mk patrol gearboxes to suit the ford 3.3L (200Ci?) And 4.1 (250ci) pre cross flow and cross flow engines.
Edited to add they also did the same to suit our Aussie holden v8s. 253 and 308 motors....But I have seen a chev350 dropped onto the same....
like a gee six
limited slip Offline
Images: 21
Has thanked: 23 times
Been thanked: 65 times
Postby 66AzPatrol » Thu Jan 02, 2020 12:09 pm
We found the adapter plate wasn’t tightened up. Also the clutch plate assembly is going into my buddies shop. That will stop the chattering when clutch pedal is released.
66AzPatrol Offline
Images: 0
Return to Projects
