Postby Esteban » Mon Jun 08, 2020 6:34 pm
They do look like the original tail lights fitted after 72 or around.
I used to have a 74 with those. They look aftermarket.
Has thanked: 3415 times
Been thanked: 958 times
Postby plateaucal » Mon Jun 08, 2020 6:39 pm
I am thinking they are better than Autozone. But just don't know if they will bolt up.
plateaucal Offline
Has thanked: 159 times
Been thanked: 448 times
Postby Flaggoni » Mon Jun 08, 2020 6:43 pm
David, I’ve got a new set of the EBAY taillights...I’ve got your address...They are headed your way... It’s close enough to your birthday.
Mild Bill
Flaggoni Offline
Has thanked: 197 times
Been thanked: 217 times
Postby L60Boerne » Mon Jun 08, 2020 7:43 pm
Mild Bill, I am humbled. I just sent a PM to a forum member before reading yours......"would it not be a wonderful earth if everyone pitched in like this forum?' The originators built it this way....
Thank you so much, I have a few items myself if you need anything. Items that Plateaucal, River, Esteban and others have go generously shared with me.
Kind regards,
David
63 Soft Top - For Sale (CCV5)
65 No Top - Presidio Patrol
66 Hard Top - CCV6
L60Boerne Offline
Images: 0
Been thanked: 1071 times
Postby RiverPatrol » Mon Jun 08, 2020 10:12 pm
L60Boerne wrote:Rob and Plateaucal - So the 66 is supposed to have the horizontal rectangle type rear lights? If so, I'll get them and have them put on in Lake City. Let me know.
Ahem.
The horizontal rear lights were not used on any of the US Patrols, those came later. The lights in the eBay listing plateaucal posted will look much better than what you have, those are probably what Flagonni is sending you. But, the absolutely correct lights, as the front turn signals, have glass lenses. Since we've already seen how poorly you take care of your glass lenses, you don't get a set of those uber rare tail lights. :snooty:
Images: 768
Has thanked: 4580 times
Been thanked: 1404 times
Postby plateaucal » Mon Jun 08, 2020 10:34 pm
Ahem.
Ouch David.
plateaucal Offline
Postby L60Boerne » Tue Jun 09, 2020 7:03 am
RiverPatrol...I'll change :liar: .
Well, you are right. The glass needs to be reserved for Patrols with less severe duty ahead of them.
Patrolling with plastic, :violin:
66 Hard Top - CCV6
L60Boerne Offline
Images: 0
Postby moore_rb » Tue Jun 09, 2020 9:16 am
The diameter of the Ebay lights in Plateaucal's link are correct for your 66.
the only very minor difference between these and the uber-rare glass taillights are the plastic lense, and the 2 little screws that hold the lense in place, and that they were made by Koito (the glass ones were made by Everwing). The Koito lamps with the screws stared showing up on Patrols in 67.
FWIW- My 66 El Bondo should also have the glass taillights and front signals, but mine is also sporting these 2-screw style lamps (Mine are original OEM Koitos that came off the red Patrol when I scrapped it.)
But hey- What are the odds that someone is EVER going to walk up to you at the gas station and ask "Why did you use 67 style tail lights on a 66 Patrol?"
Yeah, ZERO. I would be amazed if a judge at a Nissan/Datsun concourse show would even know to dock you a point for that :lol: :lol: :lol:
moore_rb Offline
Images: 68
Has thanked: 712 times
Been thanked: 1117 times
Postby plateaucal » Tue Jun 09, 2020 1:42 pm
David,
Not plastic! They use that stuff for trash bags. Just tell everyone that they are a high performance, lightweight polymer; specially designed to enhance off road performance and visibility....unlike that stuff made out of sand.
Or Special High Impact Tail-lite lens.
plateaucal Offline
Postby L60Boerne » Wed Jun 10, 2020 6:56 am
Greetings,
I was rolling and patrolling yesterday. It has become clear to me my patrols likely have different gear ratios. Here are my observations for your consideration.
Please note: CCV5 and Phoenix Patrol roll on 33s with 2" lift while Presidio Patrol rolls on the OEM 31s with no lift.
Observations
- 63 Command and Control Vehicle 5 (CCV5) is wound pretty tight at 50 MPH, which is max optimal = about 58 MPH accounting for tire size adjustment. This motor offers good torque in high gears at lower speeds while encountering rolling hills. VZ 42 Carb
- 65 Presidio Patrol (CCV6) rolls nicely at 60 MPH, though we rarely hit max highway speeds, though when at max speed it sounds smooth and not wound up. However, it lacks low end torque in the high gears while accelerating or climbing a slight hill. Rochester Carb
- 66 Phoenix Patrol (CCV7) rolls likely at 60 MPH = almost 70 MPH with tire size adjustment, it sounds like I could drive it all day at this speed. Like Presidio Patrol it lacks the torque found in the 63 at low speed 3rd gear. Not positive on Carb, Rochester I think.
Subjective Conclusion
It seems to me the 63 has different gear ratios than the 65 & 66. :think:
Your thoughts are welcome.
Patrolling and pondering,
66 Hard Top - CCV6
L60Boerne Offline
Images: 0
Postby plateaucal » Wed Jun 10, 2020 8:32 am
I drove your red one (whichever that is) and it seemed to have much longer legs than mine even though mine has taller tires. Subjective, I know. But it's got me thinking.
plateaucal Offline
Postby RiverPatrol » Wed Jun 10, 2020 9:44 am
As Esteban pointed out elsewhere, there were no gear ratio changes through the model series. Something that did change, although as far as I know no one has ever figured out precisely how or why, was the rated horsepower. The early models were rated at 135HP, then about '65 - '66 the rating changed to 145HP.
David - are all of yours running the Pertronix ignition?
Images: 768
Postby L60Boerne » Wed Jun 10, 2020 10:21 am
Thank you both and I'm glad Plateaucal noticed it too...though the Red 65 was not amongst that group...it too operates unlike the 63.
Yes, all four Patrols have the Rob Moore Petronix upgrade. :clap:
Maybe it is just the HP difference...if so... those 10 horses have long legs for sure. :dance:
Patrolling while pondering,
66 Hard Top - CCV6
L60Boerne Offline
Images: 0
Postby mdawg4x4 » Wed Jun 10, 2020 11:56 am
Did the transmission gear ratio change for high gear perhaps?
mdawg4x4 Offline
Has thanked: 344 times
Been thanked: 287 times
Postby RiverPatrol » Wed Jun 10, 2020 12:11 pm
Just because Rob is unaware what tail lights are correct for a '67, I'd like to take this moment to also remind everyone that the Pertronix upgrade was not his contribution to the Patrol community. It was I, me, myself that hand carried a water protect distributor to Duarte, climbed the flight of stairs to the office and delivered said distributor with a few thousand dollars to Pertronix themselves so they could make the ignition kit to begin with, and they eventually offered a kit for the non water-protect distributor as well. :snooty: Ok, so he published the 'How To' (on a non-stock distributor), whoopty doo. :obscene-buttred: I made the kit possible. Let's not forget our history. :character-oldtimer:
Images: 768
Return to Projects
Users browsing this forum: No registered users and 4 guests
cron
