Postby L60Boerne » Sun Jul 05, 2020 9:14 pm
Greetings,
I met my goal for the weekend. After I get the top on... it goes back to shop to fix the even bigger leaks they generated.
Patrolling again soon,
65 No Top - Presidio Patrol (CCV4 -sold)
66 Hard Top - Phoenix Patrol (CCV6)
L60Boerne Offline
Images: 0
Been thanked: 1135 times
Postby moore_rb » Wed Aug 12, 2020 5:04 pm
It's looking great David... Really nice.
Can't wait to see a couple pics with its "new neighbor" in a few days. ;)
66 Hardtop "El-Bondo Patrol", L60-00511 (sold June2020)
moore_rb Offline
Images: 70
Has thanked: 780 times
Been thanked: 1188 times
Postby L60Boerne » Wed Aug 12, 2020 5:07 pm
Greetings to all Macgyvers,
The slip yoke on the rear drive shaft was stuck. So we naturally used what was on hand to unstick it.
Worked great.
Patrolling and rolling,
L60Boerne Offline
Images: 0
Postby jwgreen » Wed Aug 12, 2020 8:02 pm
Great thinking there bud!! It's awesome when you make do with whats on hand and it works out great!!
jwgreen Offline
Images: 70
Has thanked: 77 times
Been thanked: 359 times
Postby moore_rb » Wed Aug 12, 2020 8:26 pm
brilliant...
I'd probably still be out there smacking at it with a sand-filled mallet. :tools-hammer: :tools-hammer: :tools-hammer:
moore_rb Offline
Images: 70
Postby L60Boerne » Fri Sep 11, 2020 7:14 pm
Greetings,
Phoenix Patrol has an after market radiator cap. It is not tight fitting. If anyone has one I'd sure be interested in buying one.
Patrolling to paradise,
L60Boerne Offline
Images: 0
Postby plateaucal » Fri Sep 11, 2020 8:08 pm
plateaucal Offline
Has thanked: 215 times
Been thanked: 523 times
Postby Esteban » Fri Sep 11, 2020 8:44 pm
L60Boerne wrote:Greetings,
I have these in my notes:
USE THIS VEHICLE: 1964 FORD F-100
GATES Part # 31526 - 7 psi Pressure Rating
STANT Part # 10228
STANT Part # 11228 Card Packaged
STANT Part # 10328 Safety Release Cap
STANT Part # 11328 Safety Release Cap - Card Packaged
GATES Part # 31508 Safety Release Cap
NAPA PART NUMBERS
BK 7031444 This is 7 lbs
Disclaimer: :twisted:
Edit: Probably the Stant 10228 is right. Available at Amazon. This is for the longer filler neck of the Patrol.
Has thanked: 3656 times
Been thanked: 1003 times
Postby L60Boerne » Sat Sep 12, 2020 10:20 am
Thank you Esteban, I'm going to Amazon now for your recommended cap.
L60Boerne Offline
Images: 0
Postby L60Boerne » Thu Sep 17, 2020 7:57 am
Greetings,
It is with great relief that I can report I solved my temperature sensor/gauge issue.
I had five sending units in inventory. Four that required the retaining collar, one that had the nut formed with the sensor.
Over the last two weeks we tried the four newest sensors including the last new old stock sensor on earth sent over from RiverPatrol, the two new replacements Justin discovered, then one old one with the screw stuck in it.
I only had four when we started trouble shooting this issue. Over ten days of gentle soaking I finally got the screw out of the old one so I had two with a screw and the two new Nissan replacements that required slight modifications. After two weeks non of the four would move the needle off cold but the needle did move as the key was turned on so I really feltvmy gauge was good.
Eventually after four sensors including the new oem from River I'd given up and started looking for a new cluster.
While checking my inventory shelf I found a 5th sensor.
It was an old one but missing the screw to hold the lead on...but I had two screws. I found the screw from the sensor obtained from RiverPatrol fit. This sensor was different in two ways; longer and integral nut.
Well, I drained the fluid for a 5th time yesterday while we worked on replacing the front bushings.
Now, the reason we went to the trouble is because.......this particular sensor was 1/2" longer than the others and the nut was formed into the sensor.
So we put it in and fixed a crimped hose installed by Eddy the Eagle and started it up. It worked perfectly! I am so thankful for that. Now if APT will ever send the fuel gauge back Plateaucal gave me Phoenix Patrol will have a perfectly working gauge cluster.
Lastly, after all that success we installed the door stops 50Car made for me. Love those. He is quite a resource like so many on the forum that tirelessly help us that need it so often.
Phoenix Patrol heads to Lake City next week where hopefully Ready with the Wrench Rene has a rebuilt VC42 ready for it.
Patrolling with miles of smiles,
L60Boerne Offline
Images: 0
Postby RiverPatrol » Thu Sep 17, 2020 8:06 am
Awesome that you got it working after such diligence! Odd that the other sensors didn't work. Perhaps it might have been a grounding issue? :think:
Images: 768
Has thanked: 4765 times
Been thanked: 1467 times
Postby jwgreen » Fri Sep 18, 2020 1:42 pm
RiverPatrol wrote:Awesome that you got it working after such diligence! Odd that the other sensors didn't work. Perhaps it might have been a grounding issue? :think:
Yeah sounds like a "wiring" issue like a ground.....
jwgreen Offline
Images: 70
Postby L60Boerne » Sun Sep 20, 2020 4:30 pm
Justin, We kinda came the same conclusion around here. Perhaps the collar was not providing a solid enough ground but the sensor with the nut formed into it did.
I just returned from our annual dove hunt down on the border. It was awesome as always.
I will be leaving in the morning to go north and drive Santa's Sleigh with the replacement oil pan from 50Car then coming right back after a few days in the field to load Phoenix Patrol for trip to Lake City via Dallas.
L60Boerne Offline
Images: 0
Previous
Return to Projects
