The truck sitting on her own weight!
No leaks, it rolls, stops if I use the hand brake, and steers!
One thing I was waiting on was trying to figure out the driveshaft situation. Removing the old U-Joints ruined them and there aren't any replacements. I know some have mentioned Toyota U-Joints and then grinding them down, but I didn't like that idea. I tried heat, cold, took them to a couple of shops, but nothing/nobody could do it. So I just had entirely new driveshafts made with easily replaced parts.
Now uses Dana/Spicer 1350X non-greaseable joints mounted to 3-28-777 Yokes. The main difference between these and the stock ones is basically the bore size for the joints, so we were all pleasantly surprised.
Sadly, in my gusto to clean everything I fracked up the steering box fill cap. It was covered in dirt, grease, and grime, and I didn't realize it was a plastic material until it was too late.
Need to find a replacement for that now
Next up I got the exhaust mounted up to see how well the shop did. All told, they did well considering the truck wasn't in their possession, just the old rusty exhaust. What I'm still not sure about is the exhaust strap that goes underneath the passenger side door. The shop cut it off and, though I have it hanging there, it's not doing anything. Is one really needed?
Super minor, but while I was in there getting things bolted up I fixed the air filter mounting. Prior to this I had a long screw with a few bolts & a washer for clearance going down the top into the carburetor. Needless to say, it looked like crap and I never liked it. So now both the carb & air filter side are wingnut mounted and the screw comes out the top like it should.
I also cleaned up the Alternator mount now that that everything was bolted up. That too is something I never liked, so I cut it, welded it back shorter, bent it into shape, and tidied it up a little.
Since I don't care about originality much I also went ahead and swapped the brake system to AN3 fittings all around. My old flexible hoses were shot and honestly I'm a little surprised I never ruptured a line given how they looked before. New T fittings, some adapters, and she should stop a lot better once it's all done.
Need to do some more line bending, but I need to get some body panels on first, so now I'm starting on the bed.
It's in pretty rough shape. You can see the doors are both bent, bolt holes are warped, and a plethora of other issues. The first of which
How the **** do I get to the inner bolts holding these in? It looks like you have to cut a hole and then patch it back up once done, but I'm really hoping I'm just missing something simpler.
