Been a slow month thanks to way too much going on in life. We had officially run out of space in the garage, so took a break from the truck to hire a shitty contractor to expand the garage!
After not that long at all (especially given just how much things costs these days) all three classics fit in the garage with space left over for work benches and tools.
Despite some misgivings regarding the contractor and the work done I'm glad to have the extra space. I wish I could have gone back another 5' or so but this is enough if I stop buying more things
So with that done, got back to work on the truck. I had started back on cleaning duty - the transfer case, under the cab, etc. but that wasn't working as I needed more space to work, so more body panel removal was needed.
So the grill, windshield, radiator, and entire electrical harness came out.
So with the harness out I can finally tackle the electrical system properly. It's actually worse than I thought as I'm finding bad splices, burnt wires, cut insulation, and all sorts of other goodness that comes from 53 years of usage.
Right now I'm in the stage of just cleaning up the harness, removing the old tape, and planning the rebuild of it all. Picked up some of that German goodness felt electrical tap, some labels, and already have most of the connectors, heat shrink, etc. that I'll need for the rest of it. I've certainly found/seen some missing connections, wires going to nowhere, etc. so I'm sure I'll have questions in the future if I can't find new parts to replace the old or can't make heads or tails of the hack job that's been done.
I'm going to be removing the engine/transmission/transfer case soon as well. The plan is to remove them all as a unit and place them on a dolly so I can move and clean them without too much effort. Ironically, the biggest problem is I'm running out of space. Where the (naughty word) do people put all the parts when they're doing this?
