Only a face a mother could love?
OK, what do you think, look number one................:
................or look number two??
It will look better once the paint is cleaned up and polished, and I get the really really nice front turn signal lights on that I got from RiverPatrol. Need to scare up a pair of decent headlight rings -- they don't need to be perfect, because this won't ever be a perfect Patrol. The current ones, you can't see it very well in the pictures, but they have a lot of coarse surface rust on the tops
Since I really don't think I'll ever mount the Western snowplow on the Patrol, decided to pull the support frame off. Gets a little weight off the front end. There is scant clearance between the front axle tubes and the rubber jounce bumpers -- about 1/2 of what the drawing in the service manual calls for -- and some of the reason may have been the weight of all the snow plow equipment. (This Patrol was used in the winter to plow the dealership and the car wash my family owned, and they also had some contracts to plow other businesses.) Guess at some point I'll get the front springs re-arched. The frame was a bear to get off, because the nuts/bolts were rusted up pretty bad. One came off with an impact, but I had to cut the heads off the other three with a angle grinder to get the plow frame off. (In the second picture, the tow hook and bolts have not been reinstalled.)
I also pulled the hood spotlights off, they were there for lighting when the snowplow was installed.
Of course, I'm also on the lookout for a vintage North Carolina State University Wolfpack license plate to replace the rusty bent up one.
Question: how many tow hooks were on the front of the early (circa '62) Patrols? Mine only has one, mounted on the passenger side. The bolts holding the drivers side of the bumper on (as well as the plow frame) where short ones and would not have been long enough to mount a tow hook. That doesn't mean it couldn't have been removed and shorter bolts put in, but I kinda doubt it -- why keep the hook on the passenger side and chuck the one on the driver's side?
