Postby Volkmann77 » Thu Nov 15, 2018 3:27 pm
Does anybody have the dimensions of the glass for the front doors? Looks like I will need to have some fabricated.
Volkmann77 Offline
Has thanked: 4 times
Been thanked: 16 times
Postby yuke175 » Wed Feb 20, 2019 6:33 pm
are the studs that connect the exhaust to the manifold pressed in? mine appear to be bent.
yuke175 Offline
Has thanked: 0 time
Been thanked: 31 times
Postby Esteban » Wed Feb 20, 2019 9:28 pm
yuke175 wrote:are the studs that connect the exhaust to the manifold pressed in? mine appear to be bent.
They are screwed in the manifold. Might require some days of penetrating oil to get them out. You can try putting 2 nuts on each of them, and tighten the nuts together. Hopefully you'll be able to use a wrench and get the studs out.
Has thanked: 2502 times
Been thanked: 824 times
Postby nizmut » Fri May 03, 2019 10:44 pm
What are you using for the small round hole in the trans tunnel? Also for the twin stick boot?
Robin
nizmut Offline
Has thanked: 49 times
Been thanked: 146 times
Postby nizmut » Sat May 04, 2019 5:30 pm
nizmut wrote:What are you using for the small round hole in the trans tunnel? Also for the twin stick boot?
2" plug, got it from Steele https://www.steelerubber.com/plug-floor-pan-35-3508-45
Robin
nizmut Offline
Previous
Return to General Tech
