Rust Converter - painting over it
Postby Fusanala » Sat May 25, 2019 5:45 am
Anyone use any rust converter that you can paint over when dry? In other words, no scraping, no wire brushing, etc., just convert and paint. What did you use, how did it work?
Thanx
Fusanala Offline
Lurker
Lurker
Has thanked: 0 time
Been thanked: 0 time
Postby r1lark » Sat May 25, 2019 5:53 pm
I've used Dupli-Color Rust Fix quite a bit, if I remember correctly the instructions say wait 24 hours then paint over it. Mainly I use this for smaller parts or parts that the rust can't be easily removed by grit blasting, etc. Have not had any issue with the paint when topcoating over Rust Fix.
I have not used it, but you can also top coat over Eastwood's Rust Encapsulator: https://www.eastwood.com/eastwood-rust-encapsulator-black-aerosol-15-ounce.html?SRCCODE=PLA00010&gclid=Cj0KCQjwz6PnBRCPARIsANOtCw37qP0S7yfm3p8SdnhI9AmWqwFAnF6qYwWXd1nwryQ0JRI-gSr3O9saAheLEALw_wcB
Paul
r1lark Offline
Images: 4
Has thanked: 70 times
Been thanked: 87 times
Postby moore_rb » Tue Jun 04, 2019 11:32 pm
I have painted directly over Rustoleum Rust Reformer, as well as Eastwood's Rust Converter... Both are great products and paint bonds very well to them.
moore_rb Offline
Images: 68
Has thanked: 567 times
Been thanked: 871 times
Postby dustin3n » Mon Dec 09, 2019 2:08 am
Eastwoods and Por15 are both great products.
dustin3n Offline
Has thanked: 0 time
Been thanked: 12 times
Postby moore_rb » Sun Jan 05, 2020 11:38 am
Harbor Freight also sells a spray can rust converter product that says on the label that it is paintable, but my experience with this product is that it does better if you spray it on and let it dry, then do a light sand, followed by a primer.
For a single step, combination rust treatment and primer, I still think Rustoleum's rust reformer is the best one out there... JMHO
moore_rb Offline
Images: 68
Return to General Tech
