DIYs, FAQs, How-Tos and anything else that doesn't fit in another topic
Postby Volkmann77 » Thu Nov 15, 2018 3:27 pm
Does anybody have the dimensions of the glass for the front doors? Looks like I will need to have some fabricated.
Volkmann77 Offline
Has thanked: 4 times
Been thanked: 18 times
Postby yuke175 » Wed Feb 20, 2019 6:33 pm
are the studs that connect the exhaust to the manifold pressed in? mine appear to be bent.
yuke175 Offline
Has thanked: 0 time
Been thanked: 37 times
Postby Esteban » Wed Feb 20, 2019 9:28 pm
yuke175 wrote:are the studs that connect the exhaust to the manifold pressed in? mine appear to be bent.
They are screwed in the manifold. Might require some days of penetrating oil to get them out. You can try putting 2 nuts on each of them, and tighten the nuts together. Hopefully you'll be able to use a wrench and get the studs out.
Esteban Online
Has thanked: 2598 times
Been thanked: 846 times
Postby nizmut » Fri May 03, 2019 10:44 pm
What are you using for the small round hole in the trans tunnel? Also for the twin stick boot?
Robin
nizmut Offline
Images: 0
Has thanked: 50 times
Been thanked: 150 times
Postby nizmut » Sat May 04, 2019 5:30 pm
nizmut wrote:What are you using for the small round hole in the trans tunnel? Also for the twin stick boot?
2" plug, got it from Steele https://www.steelerubber.com/plug-floor-pan-35-3508-45
Robin
nizmut Offline
Images: 0
Postby Esteban » Wed Jul 03, 2019 10:17 am
What thickness (gauge) is the sheet metal in the body of the Patrol?
I'm trying to buy some sheet metal pieces of the same gauge to start practicing with the MIG welder.
Thanks.
Esteban Online
Postby plateaucal » Wed Jul 03, 2019 4:08 pm
If I remember correctly, I used 18 gauge on mine. Based upon measurement with a micrometer.
plateaucal Offline
Has thanked: 56 times
Been thanked: 198 times
Postby Esteban » Wed Jul 03, 2019 9:32 pm
plateaucal wrote:If I remember correctly, I used 18 gauge on mine. Based upon measurement with a micrometer.
Thanks a lot. Great help. I’m going to fix a bad rust problem in the rear quarter panel, but first I have to practice a lot with my MIG welder.
The hardware store only had 22 and 16 gauge. Will practice on both.
Esteban Online
Postby nizmut » Mon Jul 22, 2019 10:07 pm
Set timing with vacuum advance hooked up or disconnected?
Robin
nizmut Offline
Images: 0
Postby Johnny Roadkill » Tue Jul 23, 2019 5:32 am
Disconnected at distributor and hose blocked...or pinched closed while connected.
You're setting "static" advance and don't want vacuum or mechanical advance fudging the setting. There shouldn't be any mechanical advance at idle but there will be vacuum advance if you don't disable it. If you don't block the hose the idle will be higher and may hunt as the manifold vacuum will suck in extra air and lean out the fuel mixture.
Cheers,
D
'93 V6 4Runner - her off roader, my daily driver.
'12 Outlander - the grumpy bunny.
Johnny Roadkill Offline
Images: 255
Has thanked: 37 times
Been thanked: 177 times
Postby Esteban » Tue Jul 23, 2019 8:26 am
Johnny Roadkill wrote:Disconnected at distributor and hose blocked...or pinched closed while connected.
Cheers,
D
I have to disagree a little bit, mostly due to the fact that at idle vacuum at the distributor is negligible and won't affect the timing setup. Vacuum develops under throttle conditions when you're demanding power of the engine.
So the bottom line is that the outcome should be the same.
Esteban Online
Postby Johnny Roadkill » Tue Jul 23, 2019 4:03 pm
Fair enough, your knowledge and experience with the P motor is acknowledged ! :)
Easy to confirm for anyone with a running Patrol, a timing light and 5 minutes to spare...sadly I'm missing the first one right now :(
Cheers,
D
Images: 255
Postby Esteban » Wed Jul 24, 2019 12:19 pm
I was going to test mine, getting readings of vacuum at the advance port at idle and at different throttle conditions, because you have me second guessing.
My dad used to do it your method. The Service Manuals have not much info on this.
Esteban Online
Postby nizmut » Sun Jul 28, 2019 10:51 am
How do you check and add steering gear lube?
Robin
nizmut Offline
Images: 0
Postby Esteban » Mon Jul 29, 2019 10:33 am
nizmut wrote:How do you check and add steering gear lube?
On top of the steering box you have a plug next to the adjusting bolt. You fill the oil up to the bottom of the fill plug threads (to allow the plug to go in again). Regular transmission oil goes there (API GL-4) 90W
Esteban Online
Return to General Tech
