Seals: transfer case input-output, pinion.
Original and compatible parts
Postby jwgreen » Wed Feb 26, 2014 9:56 pm
RiverPatrol wrote:Justin, you're even awesomer! :D :clap: :dance: :lol:
Thanks Leslie, I'm just tying to impart what little knowledge I have to this site. :D
jwgreen Offline
Images: 70
Has thanked: 43 times
Been thanked: 259 times
Postby RMP&O » Thu Apr 30, 2015 12:20 pm
This seal is still available from Nissan. Couple winters ago I walked into Napa here in my tiny little town with the seal in hand. They called their Nissan dealership they get parts from, didn't mention truck it was for but read the number off the seal. Two weeks later I had a set of seals from Nissan. Recently I have bought more of them, directly from Nissan.
RMP&O Offline
Images: 80
Has thanked: 181 times
Been thanked: 173 times
Postby RiverPatrol » Thu Apr 30, 2015 12:23 pm
What part number did you order?
Images: 718
Has thanked: 3598 times
Been thanked: 1163 times
Postby RMP&O » Thu Apr 30, 2015 6:19 pm
RiverPatrol wrote:What part number did you order?
38189-44000
http://www.amayama.com/search?region=315&q=38189-44000
RMP&O Offline
Images: 80
Postby Esteban » Thu Apr 27, 2017 5:05 pm
I ordered the following seal from eBay just to have in stock:
AVX Shaft Oil Seal TC50x73x12 Rubber Lip 50mm/73mm/12mm metric (use this for the search)
http://www.ebay.com/itm/AVX-Shaft-Oil-S ... 5d60384466
It's not double lipped as the original (to keep oil in, and water out). It does have an outer lip that will keep dust out. Will work if you're not fording any streams.
Has thanked: 2502 times
Been thanked: 824 times
Postby rdarnell » Fri May 26, 2017 9:49 am
just purchased SKF 17758 and 18979 from Rockauto... not sure when I will get around to using them though...
rdarnell Offline
Images: 156
Has thanked: 106 times
Been thanked: 158 times
Postby rdarnell » Fri May 26, 2017 9:51 am
rdarnell Offline
Images: 156
Postby Esteban » Fri May 26, 2017 10:43 am
rdarnell wrote:just purchased SKF 17758 and 18979 from Rockauto... not sure when I will get around to using them though...
I'm getting these measurements for them:
SKF 17758 (for Transfer input seal)
Width (in) 0.354--->9.0 mm
Shaft (in) 1.772--->45.0 mm
Bore (in) 2.677--->68.0 mm
SKF 18979
Width (in) 0.276--->7.0 mm
Shaft (in) 1.89--->48.0 mm
Bore (in) 2.874--->73.0 mm
If you're planning to use SKF 18979 for the Transfer case output seals, and the pinion seals, the inside dia. (Shaft) might be too tight. The shaft is 50 mm. I measured it before ordering the ones from eBay. Member 2869ral did report that the inner dia. was a bit tight, and he found the ones on eBay after that.
Postby Shad » Fri Jun 29, 2018 4:04 pm
Does anyone have an extra output shaft seal to sell.... 38189-4400?
I am out of commission until I locate one.
Thanks
Shad
425-250-8093
Shad Offline
Has thanked: 0 time
Been thanked: 0 time
Postby rdarnell » Mon Mar 25, 2019 2:18 pm
looks like the time to put all the seals I have acquired is getting close. I have ordered new bearing too!6246
rdarnell Offline
Images: 156
Postby rdarnell » Sun Apr 07, 2019 8:37 pm
Just order pinion seals from the above amayama site. The AVX 50x73x12 seals feel a little too tight for my liking.
rdarnell Offline
Images: 156
Previous
