Gasket Scans
Original and compatible parts
Postby faux40 » Mon Jul 21, 2014 12:21 am
I've been uploading all my gasket scans -- Probably should have created a single thread for them awhile ago. Please add any that you have. I've found that if I set the gasket on my flatbed scanner with a sewing tape in two directions, it works out pretty well.
I hope they're useful!
Oil Filter Housing Gasket
3358
Transmission Side Cover Gasket
3281
Transmission Small Top Cover Gasket
3273
Transfer Case Rear Main Shaft Cover Gasket
3272
Timing Cover Gasket
2906
Timing Gear Case Gasket
2907
Transmission Large Top Cover Gasket
2896
Transmission Input Shaft Seal Cover Gasket
2895
Water Pump Housing & Mounting Gaskets
2892
Thermostat Housing Gaskets
2891
faux40 Offline
Images: 635
Has thanked: 304 times
Been thanked: 513 times
Postby bosque » Mon Jul 21, 2014 6:47 pm
Good stuff, it should be like an ice cream scooper handle.....shhhhhticky!
Good effort FoFam. :clap:
    bosque Offline
    Images: 62
    Has thanked: 311 times
    Been thanked: 175 times
    Postby EricB » Thu Aug 21, 2014 1:10 pm
    Is everyone planning on taking these pics down and hand cutting out their own gaskets ?
    Or is there any interest in tracing these on the computer and then either making the files available to everyone ?
    Or potentially getting a place to laser cut them out ?
    Tracing is easy because the scans are good and have scales on them.
    Let me know?
    EricB Offline
    Images: 9
    Has thanked: 40 times
    Been thanked: 68 times
    Postby RiverPatrol » Thu Aug 21, 2014 1:26 pm
    Having computer traced files would be real nice. Are you offering to undertake this project? ;)
    Images: 718
    Has thanked: 3592 times
    Been thanked: 1163 times
    Postby bosque » Thu Aug 21, 2014 1:46 pm
    I wonder if graph paper would aid in aligning and measuring all in one scan without the tape....? :think:
    bosque Offline
    Images: 62
    Postby faux40 » Thu Aug 21, 2014 7:02 pm
    Excellent idea -- I'll try it on the next one.
    Thanks!
    faux40 Offline
    Images: 635
    Postby EricB » Fri Aug 22, 2014 11:08 pm
    Hi Leslie
    Hi guys
    Yes, I'm offering to trace all the gaskets that get scanned in and then make them available as .AI or .PDF
    Easy enough - I'll start on the ones that are already in this thread above
    Typical laser cutter size is 18" x 24" if I remember right, if we can agree on a roll of gasket material we can probably get a whole bunch cut out at once.
    EricB Offline
    Images: 9
    Postby RiverPatrol » Sat Aug 23, 2014 10:16 am
    EricB wrote:Hi Leslie
    Hi guys
    Awesome! Thank you for your contribution! :clap:
    Images: 718
    Postby faux40 » Thu Sep 04, 2014 11:06 am
    Esteban shared this scan of the fuel level sender gasket. He sent over an original, factory gasket. It's made from about 1/8" thick cork. Note that the screw holes are not symmetrical around the ring and will only fit on the tank one way.
    3581
    faux40 Offline
    Images: 635
    Postby EricB » Wed Sep 10, 2014 10:22 am
    Hi everyone
    I haven't forgotten about this - I am working through them now.
    I was delayed a bit by a work trip last week.
    I've got some questions for your faux40:
    On the lower part of the outside right edge of the scan (just before the bottom rounded corner), there is a wobble in the gasket - I'm guessing it is supposed to be straight?
    Transfer Case Small Top Cover Gasket
    It seems like the holes aren't symmetric from the left side to the right side.
    It seems like the left side holes are set in further from the outer edge than they are on the right side.
    To me this is most visible with the bottom left hole which appears to be set in much more than its right side counterpart.
    Is the gasket symmetric or not?
    On the left hand side of the scan, are the two vertical edges meant to line up? Or is there an offset in the part?
    It would seem like the two main round openings in the center of the gasket should be perfectly circular, but they are not.
    Maybe this is just a function of the scan?
    Finally could you please take a caliper to the different sized bolt holes and send me the dims to make sure I have those right ?
    Thank you !!
    -e
    EricB Offline
    Images: 9
    Postby faux40 » Thu Sep 25, 2014 6:55 pm
    Here are a couple more gasket scans:
    The water pump to head gasket:
    3649
    The oil filter housing to block gasket:
    3648
    faux40 Offline
    Images: 635
    Postby EricB » Tue Nov 11, 2014 4:57 pm
    Here is the illustrator (AI) file for the traced gaskets...
    (sorry i thought i had uploaded this a while back already...)
    Depending on the resolution of the different scans there was definitely some room for interpretation
    I would suggest printing out a set on paper, hand cutting them out, and comparing / contrasting with what the actual part requires to see how close or not the traces are
    -e
    EricB Offline
    Images: 9
