New updated compatible parts list
Original and compatible parts
Postby faux40 » Thu Aug 27, 2015 12:55 pm
ylopez wrote:YEC dist cup and rotor
Added to the parts DB.
Thanks!
faux40 Offline
Images: 635
Has thanked: 304 times
Been thanked: 513 times
Postby Esteban » Thu Aug 27, 2015 1:22 pm
This is probably for the non-water protect distributor.
Has thanked: 2498 times
Been thanked: 824 times
Postby Timoun » Tue Sep 22, 2015 10:42 pm
I was just about to order two Napa 11190 brake hoses for the front axle of my '65 L60 according to the old compatible parts list, then I checked the updated list to find they supposedly won't fit pre-68 Patrols. I checked the picture on the Napa site and the 11190 looks very close except for having a clip attachment on the female end rather than a nut. Does anyone know if this the only difference? Better yet, does anyone know the right hoses for my '65? I'm tempted to buy one of the 11190 hoses just to see if I can make it work. Thanks!
Update: 27-09-15
In case anyone is interested, the Napa 11190 hose doesn't fit earlier vehicles (at least not a 1965 L60). The length is correct, and the female end will fit the steel brake line on the axle. The clip attachment could replace the original nut attachment. However, the male end of the 11190 is too small for the fitting on the hub backing plate. I now have one new Napa 11190 brake hose in box that's free to anyone who wants to pay the postage. Also, would anyone be kind enough to tell me if they have found the correct hoses for this application?
Timoun Offline
Images: 23
Has thanked: 40 times
Been thanked: 18 times
Postby Timoun » Sat Oct 03, 2015 2:29 pm
Timoun Offline
Images: 23
Postby RiverPatrol » Tue Jun 14, 2016 11:27 am
A couple of compatible parts found by pub:
Pre-68 brake hoses, axle to hub, O'Reilly #BH 3351
U-joints: O'Reilly by Precision #331
Images: 718
Has thanked: 3592 times
Been thanked: 1163 times
Postby jwgreen » Wed Nov 16, 2016 9:26 am
Water Pump bypass hose (U shaped one) Gates 21918 $9.89 at O'reilly's. Trim to fit but does not kink.
jwgreen Offline
Images: 70
Has thanked: 43 times
Been thanked: 259 times
Postby faux40 » Wed Nov 16, 2016 10:04 am
I added it to http://parts.60patrol.com/parts
Thanks,
faux40 Offline
Images: 635
Postby nizmut » Sat Dec 17, 2016 8:00 pm
WHAT HAPPENED TO THE LIST?
Robin
nizmut Offline
Images: 0
Has thanked: 49 times
Been thanked: 146 times
Postby faux40 » Sun Dec 18, 2016 12:54 am
Looks like a dns configuration issue -- Let me see what I can come up with.
faux40 Offline
Images: 635
Postby nizmut » Fri Feb 03, 2017 7:08 pm
1969 front wheel bearing seals
TCM Part 65X88X12TC-BX
Robin
nizmut Offline
Images: 0
Postby faux40 » Fri Feb 03, 2017 7:44 pm
Okie dokie -- I just added it to the parts database at http://parts.60patrol.com/
Thanks!
faux40 Offline
Images: 635
Postby nizmut » Thu Feb 09, 2017 10:25 pm
Robin
nizmut Offline
Images: 0
Postby Carogers1 » Wed Jun 20, 2018 1:37 pm
Hello, I am trying to rebuild a steering gear from a 67 Patrol. My concern is the dude who took apart the box lost the outer race to the worm shaft bearings. I have a part number that isn't any good 4802544000 and a NSK # of R20-4. ANy help!
Carogers1 Offline
Lurker
Lurker
Has thanked: 0 time
Been thanked: 1 time
Postby AARON713 » Sun Sep 16, 2018 10:46 pm
I seriously can not thank you enough for this.
AARON713 Offline
Has thanked: 20 times
Been thanked: 29 times
Postby yitzac1990 » Mon May 13, 2019 11:07 am
I was playing on ebay and found a guy selling brand new brake cylinders for 67 - 77 Patrol front wheels:
https://www.ebay.com/itm/Nissan-Datsun- ... 1438.l2649
I googled the part number that the seller listed and found this:
https://www.komeyasale.com/index.php?ma ... s_id=15446
cheaper than the 4wd products item on ebay, and apparently free shipping, too
yitzac1990 Offline
Has thanked: 7 times
Been thanked: 16 times
