Since I haven't seen any other threads on here that deal with u-joint replacements with too much depth maybe this can be a help to some others as I experiment and try to find a suitable U-joint substitute. I'll try to post as many photos along the process as I can.
I started out by working on an emergency brake band replacement and decided to tackle U-joints since they were 50 years old and look like they haven't been serviced since day one. I began by removing the rear drive shaft/propeller that connects the rear axle and transmission. Then I gave the yoke a good clean up and Prime and paint (while taping off the inner cylinders where the U-joint caps are pressed so as to not mess with those dimensions by adding layers of paint).
After removing the forward U-joint and ordering a neapco # 2-0053 hd replacement I quickly found out that the spider would not fit into the yoke that connects to the transmission/e-brake drum. After wrestling with it for for 5 minutes I concluded that the only way it could possibly fit would be to grind either the yoke itself or the body of the U-joints which isnt an option.
The new neapco U-joint doesn't clear the forward yoke but does clear the propeller side...
The width of the spider for both the stock U-joint and Neapco U-joints are pretty close from end to end.
It seems like the width/diameterof the cylinder shafts on the spider is the issue.
The neapco U-joint is also slightly taller with the caps on.
However, the cap bearing widths are the same
I'm going to order the other suggested U joint from Napa and see if the spider cylinder diameter matches the stock diameter more closely. Napa # NPJ P331. Stay tuned. If that works I'll post some photos of U-joint installation into the propeller shaft yoke.
After a little more research and more trips to the parts stores I tried the Napa p331 u joint and brought the yoke into the store to see if it would slide on. It also would not clear the flanges of the yoke. The part number was different (u331). Next I'm on to oreilly to try theirs. Will keep you guys updated
