by G60michael » Mon Apr 13, 2020 3:35 am
Awesome reply Reddog thanks Dave. I seen this first hand on Reddogs cousin's G60 and it looks relatively factory so I'd be going that way.
I know its bit of a pain in the butt, though I don't know of any hoses otherwise suitable.
With The later heater and later radiator you do as Reddog has shown,
But regardless of what model G60 you had its actually a pain either way as the earlier ones that have a heater has the lower hose has the barb for the heater hose Vulcanised into the hose, new hoses do not have this Feature.
So with the early ones you need to make, or find a later style heater Hose "T" piece section like yours and trim the hose so it will sit nicely and look good, theb add the "T" Piece then a short straight bit onto the water pump. One good thing is the earlier radiators also had a leg that came out the bottom tank and bent up hence the hose often listed doesn't suit the late Radiators.
Either heater/radiator combo there's no direct fit up, but both easily sorted.
Hope this Helps cheers G60Mike
