The results on how many springs to remove.
Firstly the result. Stunning! Such a smooth ride. My previous springs were just solid. Every little bump in the road resulted in the Patrol vibrating up and down. It was as though I had flat spots on the tyres. If I now jump up and down on the back of the Patrol you can feel the springs move - doing what they should.
Recommendation: Yes you should do it, but read on first.
So what I did was to remove 4 leaves from my 9 leaf pack. Leaves 1,3,4,and 6. I kept the leaves that had rebound clips and of course springs 8 and 9 that bolt onto the chassis. I didn't cut the rebound clips down, just in case I need to add some leaves back in. Once painted they look OK.
My patrol was a heavy duty LWB flat tray Patrol with a H260 diff. I have only worked on the rear springs.
I pulled the springs apart, and cleaned them up. I then used
to etch the springs. However I may have used the wrong etching as later I read the label and steel wasn't mentioned.
Then I added some Polyurethane sheet between each spring - in the centre around the centreing bolt. I purchased a roll 150mm wide by 500mm long with a Thickness of 1mm from China via eBay. I cut this up into pieces about 70mm wide (the width of a spring) by 150mm long and drilled a 10mm hole in the middle.
You might be able to see the polyurethane in this image.
Finally I painted them black.
I also put in new shackle plates, shackle pins and all new rubber bushes. These were necessary in my case, but may not really add to the ride. I'll post another entry about this later.
I plan to do exactly the same to my front springs when I have time.
I have done a little 4WDing and the springs seemed fine.
I haven't tested it with a load, but for my case I'm sure it will be fine. If not I may add back a couple of springs.
Just a couple of other thing that you may find useful.
For the centering bolt I used M8 (8mm) Hex Socket Cup Head bolts The round head fitted perfectly into the location holes on the diff. The length was no of leaves x thickness of leaves + 5mm (for Polyurethane) + 10mm for the bolt nut.
When assembling the springs I used a longer bolt (any head, as long as it fitted) to pull the springs together, then used G clamps to hold the springs and then replaced the bolt with the correct length bolt.
And finally when I assembled the axles to the springs I found the the U bolts needed a 'spacer' so the nuts had thread to engage. The was because, of course, leaves were missing and the nuts didn't have any thread to tighten.
I think the massive improvement in ride and comfort was because I cleaned the springs up and placed polyurethane in between the leaves to reduce friction. It may have not been necessary to remove as many leaves as I did.
Again the result. Fantastic. While it took some effort (say 2 days) and $50 of parts it was well worth it.
Not sure if I will get there.
Not sure if I will get back.
But I usually do!!!
