by Peter60 » Tue Feb 26, 2019 4:41 am
I just put new trailer shackle plates and pins on my patrol.
The specs were identical - sorry this is in metric - 16mm holes in plates. Plates were 4 or 5 mm thick and were about the same length as the original ones. Shackle pins were 16mm thick, greasable, 100mm long with a nylon lock nut.
I ended up putting in shackle plates that were 25mm longer to give a little lift.
So if FJ have the same spec then they should work.
