FYI, these are the sizes of the battery hold down rods
The threads are 1/4-28:
I had to fabricate the longer one using 1/4” zinc rod from Home Depot. (HD also carries cold and hot rolled steel rods, however the zinc coating will not allow corrosion to form as quickly.)
The wing nut is cast not stamped steel.
Keith
