Can anyone explain to me how the wiring and tail lights work on a 69??
So I was looking over the wiring diagram to try and finish up my wiring and noticed that there seems to be no wire for a brake light really....unless I'm crazy.
The wires that run to the back are WB/WR for turn signals, Y for fuel, RB for Reverse and a GW for stop/running light.
If I'm reading the 69 diagram correctly the GW is attached to the GW that goes to the instrument back lights.
The stop switch is wired from the Hazard switch then to the Turn signal but then never exits
Anyone see something different?? So the stock round 69 tail lights are Running lights and Turn signals or are they Brake lights and Turn signals but no running light??
The later wiring diagrams show a different style taillight that has all 3 and the wiring is much different but I'm extremely confused on these 69 lights and wiring.
Edit: I did a temp wire up the way the 69 diagram shows and all I got was running lights and turn signal, no brake lights
