1969 Brake Light Mounting Bracket PDF and CAD files
Wiring diagrams, Spring specs, etc
Postby jwgreen » Wed Sep 09, 2020 2:22 pm
I was a little bored today so I thought I would draw this up in CAD so that if anyone needed to, they could make their own. It should print out on a 1:1 scale so all you need to do is cut it out and trace the outside, then use a punch to locate the holes using the + in them and drill/cut them out. Or you can take this to a fab shop and have them burn it out on a laser/plasma cutter. Hope this helps someone in need. I can provide a .DXF or .DWG file for use on a laser/plasma cutter, the site will not allow me to upload them here. :think:
Edit: the material thickness is between 14g and 1/8" so pick your poison.
jwgreen Offline
Images: 70
Has thanked: 79 times
Been thanked: 378 times
Postby Esteban » Wed Sep 09, 2020 3:12 pm
jwgreen wrote:I was a little bored today ...
You should get bored more often! :clap: :clap: :clap:
The only thing missing is the applicable year. I guess is for the rarefied 69?
Has thanked: 3751 times
Been thanked: 1011 times
Postby jwgreen » Wed Sep 09, 2020 4:03 pm
Ummmm...it's in the title of the post and I just fixed it on the PDF!! I believe it only fits the super rare, ultra sought after 69.....
jwgreen Offline
Images: 70
Return to Technical Information
