Esteban wrote:Incredible price for a modded Patrol, for sure.
Looking at the engine bay I see the chimney tube for venting the gases, so it probably came from Colombia or Ecuador (no emissions enforced then).
Notice the side windows on the back, and the Toyota FJ40 rear doors. The roof top seems to have gone under the knife as well, and the whole rear seems to be altered somehow. Pay attention to the seam line like 3 inches from the corner, as well as the rounded corners. This was probably a canvas top model, so most definitely from Colombia.
Looks good, that's for sure.
The hard top does has some confusing features. It seems the roof may be the only remnant of the original, unless someone did an excellent job recreating the lines of the original, which I've never seen anyone successfully pull off before.
mdawg4x4 wrote:Also did the battery get relocated to the engine compartment on later models?
The heater blower has been removed an the opening covered over. And no defroster vents.
Also noticed the hard top rear corners are smooth to the tub as that part of the top is no longer removable.
I would expect a true restoration for that price, but those bidding may not know the difference.
If it came from South America, which is likely as Esteban pointed out, it never had the blower or defroster vents. No, the battery was never relocated to the engine compartment by the factory. And you're correct, it would be unlikely that someone bidding at a Barrett Jackson auction would know much about the details of the Patrol.
