Approaching a Motor Rebuild
Postby yuke175 » Tue Aug 06, 2019 9:31 am
This post is for the noobs.
When approaching a P Motor, what parts are a no brainer to order and replace?
What parts are unobtanium?
I want to get everything squared away before I tear down this motor or bring it to a professional. Still undecided on which path I take.
yuke175 Offline
Has thanked: 0 time
Been thanked: 39 times
Postby RiverPatrol » Tue Aug 06, 2019 9:50 am
A gasket kit to start. Most of the actual parts you can't pre-order, because you don't know what it's going to need until you tear it apart and inspect.
Images: 768
Has thanked: 4579 times
Been thanked: 1404 times
Postby yuke175 » Tue Aug 06, 2019 10:07 am
I have an engine gasket kit here from ebay. Do they make then for the trans and transfer case?
yuke175 Offline
Has thanked: 0 time
Postby RiverPatrol » Tue Aug 06, 2019 3:49 pm
I have never seen one available.
Images: 768
Postby Peter60 » Wed Aug 07, 2019 6:37 pm
Just found this rebuild set for a gearbox on eBay AU.
https://www.ebay.com.au/itm/Gearbox-Ove ... 3d5e300184
Its from 4WD products. No real detail on what is included.
I haven't used this product but have used other 4WD Products
http://www.ebaystores.com.au/4wd-produc ... 34.c0.m322
Not sure if I will get there.
Not sure if I will get back.
But I usually do!!!
Peter60 Offline
Has thanked: 123 times
Been thanked: 179 times
Postby yuke175 » Wed Oct 02, 2019 7:44 pm
mechanic tells me lifters are worn.
Any insight on replacements?
yuke175 Offline
Has thanked: 0 time
Postby Esteban » Wed Oct 02, 2019 7:59 pm
yuke175 wrote:mechanic tells me lifters are worn.
Sorry to hear that.
I've always wondered if the face could be resurfaced at a machine shop. I know the originals are hardened, but we have better oils today.
Has thanked: 3407 times
Been thanked: 958 times
Postby yuke175 » Wed Nov 13, 2019 7:08 pm
Does anyone know where I can find lifters?
yuke175 Offline
Has thanked: 0 time
