3-speed trans rebuild
Postby krc65tan » Wed May 13, 2020 1:17 pm
I want to rebuild the 3-speed trans in my '65 Patrol but the only kit I've found so far is for 67-72. Is there a difference or can I use this kit?
krc65tan Offline
Has thanked: 5 times
Been thanked: 8 times
Postby RiverPatrol » Wed May 13, 2020 1:44 pm
It's the same trans for all the years, essentially.
Images: 768
Has thanked: 4468 times
Been thanked: 1360 times
Postby krc65tan » Wed May 13, 2020 1:52 pm
Sweet! Thank you
krc65tan Offline
Postby G60michael » Wed May 13, 2020 4:43 pm
Hi mate, there essentially the same 3 speed all the way through, they did change the countershaft/layshaft front bearing design in 1972, that's the reason they have a listing for kits upto April 1972, and from May 1972 on, the earlier bearing design is much better in my opinion.
Other then the bearing, i have not been able to find any other changes really between older model and later model box's, if it is it's only cosmetic stuff like a support mount cast to the side of the box for the later clutch slave bracket to bolt to, totally irrelivant to what your doing. Hope this helps cheers G60Mick
G60michael Offline
Images: 567
Has thanked: 131 times
Been thanked: 249 times
