Carb question
PostPosted: Mon Mar 11, 2019 7:38 pm
by uh34dusn
I have a 1980 Patrol imported from Colombia The carburetor is a Hitachi DCH 340. Is there a replacement carb for this other than Hitachi?
Re: Carb question
PostPosted: Tue Mar 12, 2019 12:41 pm
uh34dusn wrote:I have a 1980 Patrol imported from Colombia The carburetor is a Hitachi DCH 340. Is there a replacement carb for this other than Hitachi?
A Weber 32/36 will be a good choice, and probably there are others as well. Fitting the air cleaner housing will always be the more challenging part.
The Hitachi you have has the secondary body vaccum actuated, and prone to problems.
Re: Carb question
PostPosted: Mon Mar 18, 2019 1:42 pm
by uh34dusn
Thank you. I'll see if I can find one
Re: Carb question
PostPosted: Mon Mar 18, 2019 4:47 pm
by uh34dusn
I did some research and there are several Weber 32/36. Which one do I choose? I appreciate the help.
Dan
Re: Carb question
PostPosted: Mon Mar 18, 2019 7:44 pm
uh34dusn wrote:I did some research and there are several Weber 32/36. Which one do I choose? I appreciate the help.
Dan
I personally have not done anything with a Weber, but kept the reference of one that was used by a member in a now disappeared forum: Weber 32/36 DGV 5A
Check this thread:
viewtopic.php?f=19&t=5077
