Hey friends, question that I am trying to diagnose or at least probe some info for right now.
Here's the issue. 69 patrol. Original Engine runs strong, idles around 550 rpm, transmission shifts and runs smoothly while driving in gears. Clutch engages disengages fine. The exception is when I'm at a dead stop in neutral and want to shift into first gear. I press in the clutch and try to shift into first and the tranny gear appears already to be spinning at a high rate where trying to mesh produces lots of whirring grinding before it can slow down enough to mesh.
It happens most of the time. And I don't want to just keep the clutch depressed at a stoplight and wear out the throw out bearing, unless that's a good sign that it's already happened. Any insight as to what might be causing this or any similar experiences? Read this forum below and not sure if it's the same deal, and haven't taken my transmission cover off yet to see how the clutch plate is doing.
No loss of power in drivetrain at all, haven't yet tried to shift from neutral into 2nd from a dead stop to see if it's in that gear as well or just first that's hard to mesh. Any thoughts would be helpful.
viewtopic.php?f=4&t=4172&p=32656&hilit=Shifting+into+first#p32656
A little more info and wonderings: could my rpm be too high at idle? New clutch master was installed recently and bled correctly, good pressure into slave from my inspection and feel anyway.
Is this something that's generally common with patrols and just takes getting used to....haven't ever driven another to compare.
