G'day all,
I've pulled the front grill and front side panels off my '66 SWB softie (after a lot of snapping and cutting, damn cage bolts) and now I'm eyeing up removing everything else.
I can't quite work out how everything pulls apart. I can see that the driver side floor appears to be bolted to the firewall, so I should be able to take that apart, but the passenger side appears to be welded to the firewall. I also can't make heads or tail of how the tub comes away from the floors. I can obviously find the mounting bolts which attach the tub and floors to the chassis.
After scouring a load of project posts, I'm still none the wiser. If anyone knows the answer off the top of their head that would be much appreciated.
Cheers,
Richard
PS. If anyone's wrecking in Oz and has good panels, I think I may well be in the market!
