different carb
Postby Haker-98 » Sat Oct 29, 2016 4:26 pm
just wondering what other people run for carbys on their patrols
just looking for somthing thats better than the hitachi ones for second patrol ive got for offroad work
abit of extra power would be nice to! :lol:
Haker-98 Offline
Been thanked: 3 times
Postby Esteban » Sat Oct 29, 2016 8:10 pm
I've been running a Carter YF that came from a 300 cid 6 cyl Ford Bronco from the 80s, including the air cleanear combo for over 10 years. My Patrol reaches top rpms with ease. I'm happy with it.
The original Hitachi was fine but definitely had less power. The main jet carrier seized on the body and stripped the threads. Otherwise I might have kept it. It was easy to swap the main jet if you were going to higher altitudes. The change was from the ouside and done in less than 5 minutes. Good on fuel consumption too.
Getting a repair kit for the Carter is very easy as well.
Has thanked: 2881 times
Been thanked: 888 times
Postby RiverPatrol » Sun Oct 30, 2016 8:51 am
My Aussie Ute has a Stromberg on it, and it runs great. I know other Aussies run the Stromberg and like it also.
Images: 762
Has thanked: 3986 times
Been thanked: 1235 times
Postby Haker-98 » Mon Oct 31, 2016 4:31 am
thanks alot
ive heard people run holley 350cfm carbs on them
just dont know how good they are
anyway i brought an adaptor today to run one so will let you know if its any good
Haker-98 Offline
Postby Mr. Zero » Wed Jun 07, 2017 3:32 pm
I've recently swapped out my Rochester 1bbl for a Motorcraft 2150 2bbl with auto/electric choke and 2bbl-1bbl adapter. With the auto/electric choke the truck fires right up and runs smooth every time.
Per its reputation the Motorcraft has delivered fuel reliably at all of the odd angles that I've managed to get the truck into and is very responsive to throttle input. :twisted:
I'm still evaluating fuel efficiency (which I'm expecting to be improved from the Rochester) and will post that data back here when I've got it.
Michael at Gronk Performance (http://www.ebay.com/usr/ehrmannmp) jetted and tuned the carb specifically for the P motor and my elevation.
It's worth mentioning that after assembling the carb and adapter there is only enough room to run a low-profile air cleaner and 1.5 inch filter.
If you go with this carb you'll want the 1.08 Venturis for the P motor.
The original inspiration for this upgrade/mod came from this article: FORD MOTOCRAFT TWO-BARREL CARBURETOR = HILLBILLY FUEL INJECTION
Here are a couple vids of the engine running with the card installed and adjusted:
Vid #1 at engine bay.
Vid #2 at exhaust outlet.
Mr. Zero Offline
Has thanked: 4 times
Been thanked: 8 times
Postby richw » Wed Jun 07, 2017 8:06 pm
Is anyone out there running a weber?
I have not stripped down my carb yet because she runs fine and as far as I know it's original...BUT I love the simplicity of the Webers.
Sorry, not a great shot of the carb!
richw Offline
Has thanked: 2 times
Been thanked: 73 times
Postby Johnny Roadkill » Wed Jun 07, 2017 9:59 pm
richw wrote:Is anyone out there running a weber?
Not on a P motor, but on an L-series...32/36 DG(A)V has been a great carb for me - built to a plan not a price, super easy to swap out jets and straightforward to rebuild.
Also 45 DCOEs...great midrange and top end, awesome sound and even more tuneable but possibly not the best option for a P motor since 4 intake ports feed 6 cylinders and a plenum to even out the pressures kinda defeats the purpose :lol:
cheers,
D
'93 4Runner - her off roader.
'93 Pulsar - my daily driver.
'12 Outlander - the grumpy bunny, her daily driver.
Johnny Roadkill Offline
Images: 255
Has thanked: 37 times
Been thanked: 182 times
Postby RiverPatrol » Thu Jun 08, 2017 9:52 am
Mr. Zero wrote:I've recently swapped out my Rochester 1bbl for a Motorcraft 2150 2bbl with auto/electric choke and 2bbl-1bbl adapter. With the auto/electric choke the truck fires right up and runs smooth every time.
Very cool! Great information. And your Patrol looks great. Nice to know you're getting some fun use out of it.
Images: 762
Postby Mr. Zero » Thu Jun 08, 2017 10:56 am
RiverPatrol wrote:Very cool! Great information. And your Patrol looks great. Nice to know you're getting some fun use out of it.
Thanks! After years in project mode it's good to be getting in some trail time with it. Now that the project is finally coming close to completion (these things are never really "done", are they?) I will retroactively post some aspects of the build that I hope might be useful to others on the forum. ;)
Mr. Zero Offline
Postby Powder27 » Sun Mar 04, 2018 11:50 am
Any update on the Motorcraft 2150? Did you go with the "rebuilt" version or the "unmarked" casting? Are you still happy with performance (power/mpg/reliability)? I'm looking at doing this modification as well.
Powder27 Offline
Lurker
Lurker
Has thanked: 0 time
Been thanked: 0 time
Postby Toads Patrol » Tue Mar 06, 2018 6:23 pm
RiverPatrol wrote:My Aussie Ute has a Stromberg on it, and it runs great. I know other Aussies run the Stromberg and like it also.
Ditto here, Strombergs are simple, and I thought that is what all US imported Patrols came with. I've had to play around with main-jetting to some extent but seems happy now.One thing to watch for, and I ran afoul of this is to make sure the carb insulator and associated gaskets have the cutout for the vacuum passage in the carb bottom flange. If you block it the high-speed cruise feature is disabled (won't work the internal piston) and you get full rich condition - resulting in bad mileage, fouled plugs etc.
67 L60 Hardtop (since 1982)
91 Figaro
17.5 Murano AWD
Toads Patrol Offline
Images: 82
Has thanked: 15 times
Been thanked: 69 times
Postby RiverPatrol » Tue Mar 06, 2018 10:36 pm
I think you are thinking of the Rochester carb. You are absolutely correct about the insulator. I had forgotten about this but I actually took pictures to depict this. In the picture below, you can see the vacuum passage on the bottom of the carb, circled. The insulator on the left is the original one that has the cutout for the vacuum passage. The insulator on the right is a new one, that doesn't have the cutout for the vacuum passage. I had to cut it myself. This is very important, your Patrol will run too rich without this. Where have I heard that before? :think:
Images: 762
Postby faux40 » Sat Mar 24, 2018 11:59 am
I never noticed that notch! I'm going to have to pull the carb and check now! Maybe that will help the mileage. Thanks River!
faux40 Offline
Images: 658
Has thanked: 337 times
Been thanked: 570 times
Postby L60Boerne » Sun Jul 08, 2018 8:02 pm
Thank you RiverPatrol. I can't wait to discover the difference!
63 Soft Top
65 No Top
L60Boerne Online
Images: 0
Been thanked: 775 times
Postby plateaucal » Mon Jul 09, 2018 12:31 pm
The 2150 carb came with and altitude compensator. It was found on early 80' Jeep products. A nice solution when fuel injection is not possible.
plateaucal Offline
Has thanked: 59 times
Been thanked: 219 times
Next
Return to Modifications
