Seals: transfer case input-output, pinion.
Original and compatible parts
Postby jwgreen » Tue Feb 25, 2014 8:24 pm
RiverPatrol wrote:
jwgreen wrote:
2869ral wrote:I dont know how to drag the ebay link here, but they are from ultimateindsolutions they are out of Maryland seals are $5.98+$3.95shippimg.
Guess I need to do a video on posting links ;) ;)
He's using an iPad, so it's a little trickier.
I'll try to work on it this next week. :D
jwgreen Offline
Images: 70
Has thanked: 94 times
Been thanked: 547 times
Postby Esteban » Tue Feb 25, 2014 10:26 pm
Got me thinking, because I know the struggle the Ron has been facing. This is what can be done. A similar procedure will work for the iPhone.
Take a look at the picture below from the screen of an iPad (please note that the link of the actual page is nowhere to be find)
Step 1: Select the symbol at the top (arrow #1), that opens a dialog with a number of options.
Step 2: Select Copy (see arrow #2). This action copies the link of the page.
Doing the above, the following is the link from eBay to the Double Lip Seal 50x73x12 that Ron found.
http://www.ebay.com/itm/Metric-Oil-Shaf ... 1127460009
Esteban Online
Has thanked: 5568 times
Been thanked: 1435 times
Postby RiverPatrol » Tue Feb 25, 2014 10:47 pm
Esteban, you're so awesome. :D :clap: :dance:
Images: 959
Has thanked: 6777 times
Been thanked: 2290 times
Postby jwgreen » Wed Feb 26, 2014 10:51 am
To expand on Esteban's post
Go to the website and item that you want to post
Tap the little box with arrow and then tap Copy
Now return to 60 Patrol post
Select the URL button in your post
Select the cursor in between the [url] brackets then Tap Paste
Now you can select Preview
And your link should show up in Blue
Hope this helps and is a little easier to follow.
jwgreen Offline
Images: 70
Postby RiverPatrol » Wed Feb 26, 2014 11:12 am
Justin, you're even awesomer! :D :clap: :dance: :lol:
Images: 959
Postby jwgreen » Wed Feb 26, 2014 9:56 pm
RiverPatrol wrote:Justin, you're even awesomer! :D :clap: :dance: :lol:
Thanks Leslie, I'm just tying to impart what little knowledge I have to this site. :D
jwgreen Offline
Images: 70
Postby RMP&O » Thu Apr 30, 2015 12:20 pm
This seal is still available from Nissan. Couple winters ago I walked into Napa here in my tiny little town with the seal in hand. They called their Nissan dealership they get parts from, didn't mention truck it was for but read the number off the seal. Two weeks later I had a set of seals from Nissan. Recently I have bought more of them, directly from Nissan.
RMP&O Offline
Images: 80
Has thanked: 181 times
Been thanked: 174 times
Postby RiverPatrol » Thu Apr 30, 2015 12:23 pm
What part number did you order?
Images: 959
Postby RMP&O » Thu Apr 30, 2015 6:19 pm
RiverPatrol wrote:What part number did you order?
38189-44000
http://www.amayama.com/search?region=315&q=38189-44000
RMP&O Offline
Images: 80
Postby Esteban » Thu Apr 27, 2017 5:05 pm
I ordered the following seal from eBay just to have in stock:
AVX Shaft Oil Seal TC50x73x12 Rubber Lip 50mm/73mm/12mm metric (use this for the search)
http://www.ebay.com/itm/AVX-Shaft-Oil-S ... 5d60384466
It's not double lipped as the original (to keep oil in, and water out). It does have an outer lip that will keep dust out. Will work if you're not fording any streams.
Esteban Online
PreviousNext
