Starter
Postby Esteban » Wed Mar 02, 2016 4:29 pm
There's a lot of information scattered about starters in the forum, to the point that it's difficult to find a meaningful answer. Maybe we should address them here. Member mtnPatrol has asked some questions regarding dismantling the starter to do some maintenance and polish the commutator. Please feel free to comment your own experiences, and tips, and make corrections to this notes, since it will help all of us.
mtnPatrol wrote:I have the starter off the Patrol and have begun tearing it down to service. However, I can't figure out how to remove the armature bearing in order to remove the armature. I don't want to destroy the bearing. The only thing I can really do as it sits is polish the commutator.
The engine service manual recommends changing brushings under 1/2". Two of my four are 7/16". The other two are 1/2". I imagine with new starters available for $100 once you start replacing parts you might as well get a new starter?
A couple of other things. In the service manual, disassembly starts with removal of the head cover. When the manual references head, is that what faces the front of the car? Also, is the head cover the thin plate at the very end/head or is it the approximately 1 1/2" wide housing which holds the brushes. I thought the end/head cap should come off but both pieces came off together. The end cap looks to be rusted so maybe that's why it didn't come off.
The few times that I have taken apart the starter motor, was before I had a Service Manual or Parts Manual in front of me. After looking at the Manual, this seems to be one of those instances that it's probably better no to have a manual, since the instructions are the most incoherent ones that I've seen (this are for the starter in use up to Feb-74). The following is a quote from the Nissan Engine Model P Service Manual with some typos corrected:
1. Removal
1) Remove the starter pedal and remove starter motor from engine.
2) Loosen two through screws and remove head cover.
3) Remove armature shaft center bearing and pull out armature.
4) Remove shift lever from head cover.
5) Remove pinion and clutch assembly.
6) Remove foot switch.
I don't have a clue what the starter pedal or the foot switch are. Head cover is confusing and not in tune with the parts manual. Please refer to the following picture from the 1973 Parts Manual. I have added the name of some of the components:
What I have done to dismantle, and by referring to the above picture is the following:
1) Disconnect Battery
2) Disconnect wire terminals at starter
3) Remove two bolts securing starting motor to transmission case. Pull starter assembly forward and remove starting motor (from 78 manual)
4) Remove two screws (#30) securing magnetic switch assembly (#17) and remove magnetic switch or solenoid.
5) Remove pin securing shift lever (#26) (this will allow later for pulling the entire assembly from the gear case #22)
6) Loosen two through screws (#21) and remove rear cover (#24) (shown with dust band that covers holes)
7) Pull out from the gear case (#22) the following simultaneously: the armature assembly (#2), center bearing plate (#6), shift lever (#26)
If cleaning and oiling the bearings again is only needed, it's probably all that needs to take place. Greasing the tracks of the Bendix can also be accomplished, as well as checking the wear conditions of the bearings, specially the outer ones, #12 and #23. It will be great if somebody can post the measurements of these bearings. Please note that there's also a center bearing. Unique to the Patrol and probably explains how long this starters last. If you want to continue dismantling:
8) Remove pinion stopper (#5) located at the end of armature shaft. To remove stopper, first move stopper toward pinion and after removing stopper clip, remove stopper with overrunning clutch assembly (bendix) from armature shaft. (copied from 78 Manual)
At this point, the typical checks of a starter motor can be done and follow the Service Manual. This will be a good time to polish the commutator by hand. I have done it with 600 grade wet sandpaper.
Edit: I found the following that needs to be mentioned:
The name Bendix gear strictly applies to the spiral drive mechanism of an inertia-type starter. However, the term is sometimes used for the pre-engaged starter mechanism.
Has thanked: 5568 times
Been thanked: 1435 times
Postby RiverPatrol » Wed Mar 02, 2016 5:28 pm
Excellent Esteban! I made this a Sticky. :clap: :clap: :clap:
Images: 959
Has thanked: 6777 times
Been thanked: 2290 times
Postby mtnPatrol » Thu Mar 03, 2016 10:53 am
I'm in the middle of disassembling my starter for service. While following the Engine Service Manual I became stuck on step #3, removing the armature shaft center bearing. I don't see how to get in there to remove the bearing located in the center of the base of the armature. You can see that bearing here:
Using Esteban's excellent guide, I also removed the solenoid and shift lever pin. Still, I cannot remove the armature assembly. It seems as though it is getting hung up on the shift lever. I haven't given it a good tug. Maybe that is what it needs??? However, I don't see how the shift lever can possibly pull out with the armature, through the gear case. It sits a good 1 1/2" above the gear case. See here:
The pinion stopper, pinion, and center bearing plate are not seized and move on the shaft. See them here:
mtnPatrol Offline
Has thanked: 43 times
Been thanked: 32 times
Postby mtnPatrol » Thu Mar 03, 2016 11:06 am
Is it possible for the rubber dust cover, the black rubber piece at the base of the solenoid housing in picture #2, to be causing an issue? As you can see, that piece wraps over the front lip but it also wraps down over the back lip. That is listed as part #34 in the 1971 parts manual and #25 (one of two parts) in the 1973 parts manual.
mtnPatrol Offline
Postby Esteban » Thu Mar 03, 2016 11:19 am
mtnPatrol wrote:... I also removed the solenoid and shift lever pin. Still, I cannot remove the armature assembly. It seems as though it is getting hung up on the shift lever. I haven't given it a good tug. Maybe that is what it needs??? However, I don't see how the shift lever can possibly pull out with the armature, through the gear case. It sits a good 1 1/2" above the gear case. See here:
In your second picture, in front of the shift lever there's a rubber piece that's covering the opening in the gear case. That's preventing the shift lever from coming straight out with the armature assembly. It's probably stuck after so many years. Make sure that the pin where the shift lever pivots is removed.
Finally we're getting some pictures of an opened starter. This will definitely help others.
Postby mtnPatrol » Thu Mar 03, 2016 1:13 pm
Does that rubber dust cover attach to the lever in any way or does it just sit over the lip of the housing? Does it normally come out when removing the armature assembly, do you manually remove it, or does it stay in place?
Pin is removed and the lever pulls up and pushes down a bit.
mtnPatrol Offline
Postby Esteban » Thu Mar 03, 2016 1:21 pm
The rubber dust cover just sits over the housing. Pry it out with something. Once it's out, the whole armature assembly including the shift lever should come out.
Postby mtnPatrol » Thu Mar 03, 2016 1:37 pm
Here is a closer view of the end of the armature assembly (the end toward the rear cover). Protruding from the gear case you can see at the center, around the shaft, what looks to be a bearing. Around it is the commutator.
Here is looking down into the rear cover. The brushings are the four little rectangles you see. They are screwed onto springed levers. At the very center is a bearing which is pressed into the housing. If you look down to the end of the hole you see the rear cover.
mtnPatrol Offline
Postby mtnPatrol » Thu Mar 03, 2016 1:49 pm
Here are some measurements I have taken.
Nose Bearing (#23)
    OD - 5/8
    ID - 1/2
Rear Bearing (#12)
    OD - 23/32
    ID - 19/32
Both bearings have a 1/16" thick wall.
Brushings (#16)
3/4" Height x 1/4" Length x ?Width (mine have worn to 7/16"-1/2") - Measurements as if looking at them from where they face the armature.
mtnPatrol Offline
Postby mtnPatrol » Thu Mar 03, 2016 1:51 pm
Esteban wrote:The rubber dust cover just sits over the housing. Pry it out with something. Once it's out, the whole armature assembly including the shift lever should come out.
Will do.
mtnPatrol Offline
Next
cron
