Complete soft top frame
Parts for sale, or free
Postby plateaucal » Thu Aug 18, 2016 6:21 pm
Just thought I would toss this out there to see if there is any interest. As best as I know this is a complete frame. It has some little, but important, details that some of the repro's seem to be missing.
plateaucal Offline
Has thanked: 43 times
Been thanked: 153 times
Postby L60Boerne » Thu Aug 18, 2016 6:45 pm
Thank you, is that an original frame? I envy your rust free pictures.
Patrolling to Paradise,
L60 Boerne
63 Soft Top
65 No Top
L60Boerne Offline
Has thanked: 2 times
Been thanked: 626 times
Postby rrodriguezsal » Thu Aug 18, 2016 9:09 pm
Hi. My reproduction is for model 1968 and forward. You are rigth mine in my pictures is different. What midel is your car? After 1968 the rear pipe is bolted on top of car body. In oldest models the rear Pipe croos the top of body and is bolted on bottom. I am complete sure because I have a 1964 and 1981 100% original. There a couple details more different depending of model. Please see pictures that I will load. When some body ask for one is necessary clarify the model of the car. I can build for any model. Thanks
rrodriguezsal Offline
Images: 126
Has thanked: 75 times
Been thanked: 170 times
Postby rrodriguezsal » Thu Aug 18, 2016 9:23 pm
8
Images: 126
Postby rrodriguezsal » Thu Aug 18, 2016 11:50 pm
Please Note that this frame match with my blue Patrol 1981, and is the same of my pictures of a frame under construcción. It was take from manual section spare Parte 1973.
Images: 126
Postby rrodriguezsal » Fri Aug 19, 2016 12:12 am
On 1968 frame changed at least for some countries
Images: 126
Postby RiverPatrol » Fri Aug 19, 2016 9:43 am
Good points Raul, thank you.
I think the one in the first picture is a '67. That is the only year I know that had the support from the edge of the tub to the top between the two side windows. Prior and later years did not have that. The frame seems mostly complete. The only pieces I see missing are #45 in the parts diagram. These are usually missing and don't detract from the use. Someone added lift dot studs on the piece above the doors, but that can easily be fixed.
L60Boerne - yes, this is an original frame.
Images: 718
Has thanked: 3394 times
Been thanked: 1119 times
Postby rrodriguezsal » Sat Aug 20, 2016 9:14 pm
RiverPatrol wrote:Good points Raul, thank you.
Thaks Riverpatrol. You are right. On my puctures I do not show part #45. It is used on original canvas to keep tense the canvas.
Images: 126
Postby Metaxas » Mon Aug 22, 2016 7:09 am
Hola
Estoy interesado en el frame
Tengo un Patrol chassis corto
Como hariamos para concretar el negocio?
Tambien necesito la lona
Saludos
Metaxas Offline
Has thanked: 7 times
Been thanked: 3 times
Postby Edgar » Thu Mar 14, 2019 9:16 am
Anytime I have a question, I just have to read through the different threads and you have already answered it. I was wondering what part #45 was for. Now I know. I have the original canvas frame for a 1967 and it seems pretty complete from the diagram. I do not however have the canvas for it.
Edgar Offline
Images: 53
Has thanked: 27 times
Been thanked: 30 times
Postby RiverPatrol » Thu Mar 14, 2019 2:58 pm
Part #45 (and #44) are for the bottom of the side curtain. They actually slide through a long loop sewn into the side curtains. I think the purpose is to keep the side curtain from flapping while driving, to keep it stable. Originals are rare, even with complete original soft tops; of three I think I have one set. A makeshift set can easily be made.
Images: 718
Postby Edgar » Fri Mar 22, 2019 8:22 am
I actually do have these original pieces (#44 and #45) so I should be good. I just didn't know their purpose as there was not a shred of canvas left on Edgar.
Derek
Edgar Offline
Images: 53
Postby RiverPatrol » Fri Mar 22, 2019 9:34 am
You're very fortunate.
Images: 718
Return to Parts
cron
