69 rat house
Postby L60Boerne » Wed Jul 18, 2018 7:08 am
Robin, I will be bringing back two complete axles in early August that Plateaucal gave me. They came from his donor and it was in very good shape from the parts I've seen. My plan was for Rafael to rebuild them to "as new" for someone.. someday. But if you need parts I will likely have them.
Concerning the rear gears. I was given a locked set of rear gears, my mechanic was afraid for me to use them so I still have them if you want them.
Regards,
l60Boerne
63 Soft Top
65 No Top
L60Boerne Offline
Has thanked: 2 times
Been thanked: 695 times
Postby nizmut » Fri Jan 25, 2019 11:50 pm
Well 2018 is over. Still trying to catch my breath. Fire clean up, then catching up on all the work that was set aside was brutal.
I was able to get my rear end fixed. Sourced all the bearings and dropped it at my buddies shop in Auburn CA. His buddy from the the shop next door walked in and said "hey that's a Patrol axle". So he rolled the cart next door and fixed it between jobs :dance: :dance: :dance:
So WFO Concepts has some people in the know.
Since then I have been swamped but got the axles with new bearings and seals, made the bearing tool
next chance will be brakes.
Hopefully I will get to work around here, but heard we are sending crews to the Paradise clean up. Just what I need, 3 months of nights, then sent out of town.
Robin
nizmut Offline
Has thanked: 49 times
Been thanked: 146 times
Postby mad4hws » Sat Jan 26, 2019 6:35 am
Robin - slow progress is better than no progress. Keep up the good work. Maybe you and I will finish at the same time - in the mId 2020s.
mad4hws Offline
Images: 211
Has thanked: 114 times
Been thanked: 180 times
Postby nizmut » Sat Apr 06, 2019 10:34 pm
So when I pulled the sway bar off I snapped all the bolts in the frame, so drilled and tapped those today. Trimmed the sleeves for the spring bushings, then hung the front of the springs.
Then just cleaned up and painted some parts, need to let the swaybar dry.
Know anyone that need some old bastard pack springs or a winch? The fronts have 2 extra leaves, the rears have 3, want to talk about a rough ride. The marks doesn't have a place for a pto, so the winch isn't doing me any good.
Been able to get out in the shop a little, so relined brakes, turned drums, new wheel cylinders, and lines. I'll swap out the soft line once it's under the Patrol.
Robin
nizmut Offline
Postby RiverPatrol » Sun Apr 07, 2019 9:45 am
The Marks requires a rear PTO.
Images: 718
Has thanked: 3601 times
Been thanked: 1164 times
Postby nizmut » Sun Apr 14, 2019 12:15 am
So I had last Monday off and got a little done on the patrol, doing every thing by myself lets me be creative.
First you get this pig out of the shop and back to the patrol. (It's really not that bad until you mount the brakes and drums)
Then you get it ready to go under the Patrol.
Then you put it over the springs and find out they sent you the wrong u-bolts
So you spend an hour chasing the threads on the old u-bolts and go order some new ones.
Robin
nizmut Offline
Postby nizmut » Sun Apr 14, 2019 10:02 pm
So while I was waiting around for u-bolts I cleaned up my shackles then yesterday pressure washed all the old grease old grease from the hangers. Pushed the pins out of the shackles and rotated them 180° since they only wear on one side. Then had lunch with the in laws. After lunch the drive way had dried up some, so I hung the rear of the springs. Then the mailman showed up with my u-bolts. Off with the old and on with the new. New grease zerks then in for the eve. Today I hung the new shocks, sway bar, and drive shaft.
Then I put the tires back on set on the ground and tightened up every thing.
Robin
nizmut Offline
Postby Edgar » Mon Apr 15, 2019 8:52 am
It is looking great! This will definitely be ready for the hunt this year!
Edgar Offline
Images: 55
Has thanked: 72 times
Been thanked: 46 times
Postby nizmut » Tue Apr 23, 2019 10:56 pm
All new hard and soft brake lines are installed, bled the brakes.
Rebuilt the Clutch master cylinder, freed up the adjuster. Have a new slave cylinder to go in. Have new soft line, and material to make a new hard line. Need to grab a couple copper washers, and a return spring and we be driving.
Looks like Energy Suspension 9.8106 sway bar end link bushings are what fit. let you know in a couple days.
Oh yeah, better not forget to fill the rear diff.
Clearing all the extra stuff from under the hood, pulled the tank valve and all the extra hoses. Next will be the PA speaker, and all the go nowhere wires.
Robin
nizmut Offline
Previous
Return to Show us Your Patrol!
Users browsing this forum: Google [Bot] and 0 guests
cron
