Postby Volkmann77 » Thu Nov 15, 2018 3:27 pm
Does anybody have the dimensions of the glass for the front doors? Looks like I will need to have some fabricated.
Volkmann77 Offline
Been thanked: 37 times
Postby yuke175 » Wed Feb 20, 2019 6:33 pm
are the studs that connect the exhaust to the manifold pressed in? mine appear to be bent.
yuke175 Offline
Has thanked: 0 time
Been thanked: 52 times
Postby Esteban » Wed Feb 20, 2019 9:28 pm
yuke175 wrote:are the studs that connect the exhaust to the manifold pressed in? mine appear to be bent.
They are screwed in the manifold. Might require some days of penetrating oil to get them out. You can try putting 2 nuts on each of them, and tighten the nuts together. Hopefully you'll be able to use a wrench and get the studs out.
Has thanked: 5548 times
Been thanked: 1432 times
Postby nizmut » Fri May 03, 2019 10:44 pm
What are you using for the small round hole in the trans tunnel? Also for the twin stick boot?
Robin
nizmut Offline
Has thanked: 81 times
Been thanked: 173 times
Postby nizmut » Sat May 04, 2019 5:30 pm
nizmut wrote:What are you using for the small round hole in the trans tunnel? Also for the twin stick boot?
2" plug, got it from Steele https://www.steelerubber.com/plug-floor-pan-35-3508-45
Robin
nizmut Offline
Postby Esteban » Wed Jul 03, 2019 10:17 am
What thickness (gauge) is the sheet metal in the body of the Patrol?
I'm trying to buy some sheet metal pieces of the same gauge to start practicing with the MIG welder.
Thanks.
Postby plateaucal » Wed Jul 03, 2019 4:08 pm
If I remember correctly, I used 18 gauge on mine. Based upon measurement with a micrometer.
plateaucal Offline
Has thanked: 266 times
Been thanked: 771 times
Postby Esteban » Wed Jul 03, 2019 9:32 pm
plateaucal wrote:If I remember correctly, I used 18 gauge on mine. Based upon measurement with a micrometer.
Thanks a lot. Great help. I’m going to fix a bad rust problem in the rear quarter panel, but first I have to practice a lot with my MIG welder.
The hardware store only had 22 and 16 gauge. Will practice on both.
Postby nizmut » Mon Jul 22, 2019 10:07 pm
Set timing with vacuum advance hooked up or disconnected?
Robin
nizmut Offline
Postby Johnny Roadkill » Tue Jul 23, 2019 5:32 am
Disconnected at distributor and hose blocked...or pinched closed while connected.
You're setting "static" advance and don't want vacuum or mechanical advance fudging the setting. There shouldn't be any mechanical advance at idle but there will be vacuum advance if you don't disable it. If you don't block the hose the idle will be higher and may hunt as the manifold vacuum will suck in extra air and lean out the fuel mixture.
Cheers,
D
Johnny Roadkill Offline
Images: 255
Has thanked: 42 times
Been thanked: 246 times
PreviousNext
Return to General Tech
cron
