Postby L60Boerne » Tue May 07, 2019 10:17 pm
Esteban your advice is excellent as usual. I see your link indicates a 7 mm seal while someone else is referencing an 8 mm seal. I bought the 7mm. Perhaps both fit, regardless I really appreciate your help as always.
Patrolling with passion,
63 Soft Top - For Sale (CCV5)
65 No Top - Presidio Patrol
66 Hard Top - CCV6
L60Boerne Offline
Has thanked: 4 times
Been thanked: 993 times
Postby L60Boerne » Mon May 13, 2019 9:27 pm
Greetings,
With much help from nearly everyone Command and Control Vehicle 5 was field tested on the third most aggressive ranch I field test my vehicles on.
Next stop, Lake City, CO.
All improvements passed. The hand throttle was effective at 2,000 ft of elevation. The beefed up leaf springs did not collapse and the steering was much tighter.
The hill climbs require both hands and the pictures never accurately depict the angle but I assure you this Patrol tested today.
Patrolling again,
66 Hard Top - CCV6
L60Boerne Offline
Postby L60Boerne » Mon May 13, 2019 9:57 pm
One last picture from the trail.
66 Hard Top - CCV6
L60Boerne Offline
Postby Edgar » Tue May 14, 2019 6:56 am
That vehicle was made for that environment. It looks great!
Edgar Offline
Images: 65
Has thanked: 161 times
Been thanked: 68 times
Postby Esteban » Tue May 14, 2019 6:59 am
Edgar wrote:That vehicle was made for that environment. It looks great!
I second that! Beautiful pictures of the Patrol and the scenery. :clap: :clap: :clap:
Has thanked: 3283 times
Been thanked: 943 times
Postby RiverPatrol » Tue May 14, 2019 8:05 am
Excellent news, great trip. The picture of the badge with trail brush stuck in it is priceless, it tells a tale. 8-)
Images: 768
Has thanked: 4469 times
Been thanked: 1360 times
Postby L60Boerne » Tue May 14, 2019 12:33 pm
The only remaining serious flaw is the lack cup holders. I still think putting them behind the front seat is best as the front area is already small enough but that isn't easy as the seats actually lean back over the centerline of the leading edge of the tub.
Hey with all that new "wall to wall" carpet coming I surely can't soak it in Rebecca's Creek from my cups falling off the hand holding bar. Yikes, I hope I don't have to start taking off my shoes before I get into drive?
Patrolling without cup holders,
66 Hard Top - CCV6
L60Boerne Offline
Postby Esteban » Tue May 14, 2019 2:02 pm
L60Boerne wrote:The only remaining serious flaw is the lack cup holders. I still think putting them behind the front seat is best as the front area is already small enough but that isn't easy as the seats actually lean back over the centerline of the leading edge of the tub.
With those steep hills you'll probably need a Self-Leveling Cup Holder :twisted:
Postby rjiggy » Tue May 14, 2019 3:38 pm
My first Patrol had these mounted to the dash or doors (can't remember). Minimal spillage, period correct and sty-ro-foam insulation to boot.
rjiggy Offline
Has thanked: 131 times
Been thanked: 144 times
Postby L60Boerne » Tue May 14, 2019 7:12 pm
Thank you but those would become the 33rd identifiable rattle noise. I have capped my identifiable rattles at 33 per Patrol.
But I do appreciate the offer.
I wonder if those Oompa Loompas are still around? I could hire one to just sit in back and hold the cup. Sure they sing from time to time but I already know the tunes and they don't take up much space or weigh very much. I'll call Wonka and see.
Patrolling when possible,
66 Hard Top - CCV6
L60Boerne Offline
Postby MadTripper » Fri May 31, 2019 6:52 am
Incredible job and I'm glad to see it finally got the love it deserved.
Tripper
MadTripper Offline
Images: 47
Has thanked: 41 times
Been thanked: 79 times
Postby L60Boerne » Fri May 31, 2019 7:01 am
Thanks Trip, You had it in the right shape it just needed a few things. I still love that PTO winch as much as anything. It will be loaded it up next weekend for the summer in Lake City.
Patrolling again soon,
66 Hard Top - CCV6
L60Boerne Offline
Postby MadTripper » Sat Oct 12, 2019 11:03 am
The winch was definitely a plus. I did have to fabricate the engagement handle assembly so prior to that it wasn't as fun to use. Great job and I'm so glad it is getting used.
Tripper
MadTripper Offline
Images: 47
Postby L60Boerne » Sat Oct 12, 2019 11:05 am
Greetings to all,
I need to replace the steering box seals in my 63. Does anyone happen to know the size or source?
Patrolling in paradise,
66 Hard Top - CCV6
L60Boerne Offline
Postby Esteban » Sat Oct 12, 2019 12:40 pm
David, I used this one from eBay:
Metric Oil Shaft Seal 32 x 45 x 7mm Double Lip
https://www.ebay.com/itm/Metric-Oil-Sha ... 2555197856
The original is 32 x 45 x 8mm. The above one worked really good. In a way it was better that the thickness was less, since it will avoid the area where the old seal left its mark.
PreviousNext
Return to Projects
cron
