PTO Winch
Original and compatible parts
Postby Edgar » Tue Mar 19, 2019 11:39 am
I would love to add a front PTO Winch to Edgar. Could you all please provide the models/brands that I ought to be looking for that are compatible with the early model Patrols?
Edgar Offline
Images: 55
Has thanked: 77 times
Been thanked: 47 times
Postby RiverPatrol » Tue Mar 19, 2019 12:37 pm
The PTO that was considered 'factory' used a Koenig winch and a factory PTO unit. Pretty rare. In Australia they've used Thomas winches, I'm not sure which PTO though. Some folks have gone with electric winches. I have a PTO unit and Koenig winch I'd be willing to let go but I don't know how it would get to you. I can't even lift the winch myself.
Images: 718
Has thanked: 3644 times
Been thanked: 1176 times
Postby curlrider11 » Tue Jul 09, 2019 10:38 am
Don't mean to hijack the thread, but this is related to winches so i thought i'd ask here. Anyone experience difficulty shifting smoothly when installing the PTO?
I test fit a PTO transmission box that i have and I've experienced elevated noise from the winch transmission when not engaged (in neutral and not shifted to "on"), and now difficulty downshifting from 3rd to 2nd (doesn't want to go into 2nd easily) and from neutral to 1st at stops (needs to roll a tiny bit to engage). River, any experience with this and what might be a cause? oil levels are good, don't know if it's a shim/spacing issue. I used a sealant instead of a gasket to make a seal between the gearbox and transmission for the PTO.
If you want me to ask this q in another thread i can move it....
"Say not,"why were the old days better than these?", for it is not from wisdom that you ask this." - Ecc 7:10
curlrider11 Offline
Has thanked: 15 times
Been thanked: 92 times
Postby curlrider11 » Tue Jul 09, 2019 2:39 pm
may have solved my own problem through this video. Sounds like i have the exact issue. shimming... hm.
https://www.youtube.com/watch?v=BV15pJWkLOU
anyone confirm this?
curlrider11 Offline
Postby RiverPatrol » Wed Jul 10, 2019 8:18 am
I can't confirm but it would make sense. The one I had with the PTO shifted fine. It didn't have any shims.
Images: 718
Postby curlrider11 » Wed Jul 10, 2019 4:14 pm
After the PTO gears came off, i cut a 1/8" thick shim (I.e. a thicker gasket) from cork/rubber and reinstalled with a little RTV. It now engages and disengages perfectly, and also shifts through all drive gears up and down smoothly. Very surprised that the PTO gear caused the problem with the main gears. Seems so far like the thicker shim took all the noise away, and the problem was resolved.
In case anyone has any future issues maybe that'd be helpful to know. I never would have thought the two would affect each other like that.
curlrider11 Offline
Postby Esteban » Wed Jul 10, 2019 9:45 pm
Congratulations! Glad you found the video. Very difficult to figure out that. For me would have been even worse the problem since I love silicone!
Has thanked: 2542 times
Been thanked: 833 times
Postby RiverPatrol » Thu Jul 11, 2019 7:35 am
Esteban wrote:Congratulations! Glad you found the video. Very difficult to figure out that. For me would have been even worse the problem since I love silicone!
Which makes sense because I am anal and used a gasket when I reinstalled the PTO. :lol:
Images: 718
