Postby nizmut » Sun Aug 11, 2019 2:07 pm
What is this?
Robin
nizmut Offline
Has thanked: 58 times
Been thanked: 166 times
Postby Esteban » Sun Aug 11, 2019 2:40 pm
Looks like somebody capped the old style breather tube with that gizmo.
In older Patrols or in regions without emissions requirements, a chimney pipe coming out from that hole in the block allowed the crankcase fumes to vent freely.
Esteban Online
Has thanked: 3499 times
Been thanked: 983 times
Postby nizmut » Sun Aug 11, 2019 3:19 pm
Guess I'll open it up and see if it is a pcv device.
Robin
nizmut Offline
Postby nizmut » Fri Aug 23, 2019 11:15 pm
What are you using for the heater fresh air flapper gasket?
Robin
nizmut Offline
Postby Mattbob53 » Sun Jan 19, 2020 7:38 pm
Body to frame bushings... two steal plates or one? Pretty sure I have seen both while talking apart.
Mattbob53 Offline
Has thanked: 27 times
Been thanked: 112 times
Postby moore_rb » Sun Jan 19, 2020 8:34 pm
Mattbob53 wrote:Body to frame bushings... two steal plates or one? Pretty sure I have seen both while talking apart.
One per body mount- Rubber against frame, then shim between rubber and body
moore_rb Offline
Images: 70
Has thanked: 737 times
Been thanked: 1142 times
Postby Mattbob53 » Sun Jan 19, 2020 8:44 pm
Thank you sir, going to make some new shims, does it make more sense to put shim in middle? Metal on metal isn’t some thing im use to
Mattbob53 Offline
Postby moore_rb » Sun Apr 12, 2020 11:59 am
Mattbob53 wrote: does it make more sense to put shim in middle? Metal on metal isn’t some thing im use to
you mean like using thinner rubber, and sandwiching the shim between two rubber pieces per mount?
I think either approach would work fine, and if you are cool with the extra effort, then go for it :handgestures-thumbup:
I certainly can't see how it would hurt
moore_rb Offline
Images: 70
Postby jwgreen » Sat Apr 18, 2020 4:38 pm
Looked around but didn't find the answer so.....
Anyone have a replacement source or the size and thread count for the grease zirks on the drive shafts?
jwgreen Offline
Images: 70
Has thanked: 73 times
Been thanked: 325 times
Postby Flaggoni » Sat Apr 18, 2020 8:09 pm
Mine are 1/8 pipe thread. They have a 10MM hex head.
Mild Bill
Flaggoni Offline
Has thanked: 200 times
Been thanked: 219 times
Postby moore_rb » Sat Apr 18, 2020 9:29 pm
Yeah, What he said ...
moore_rb Offline
Images: 70
Postby jwgreen » Sun Apr 19, 2020 7:08 pm
Ok, Thanks guys!!
jwgreen Offline
Images: 70
Postby plateaucal » Sat Jul 25, 2020 2:41 pm
This were in my parts cache that I got with the Patrol. Are they Patrol parts?
plateaucal Offline
Has thanked: 170 times
Been thanked: 472 times
Postby RiverPatrol » Sat Jul 25, 2020 4:13 pm
The piece on the left is, I don't recognize the other piece. The one on the left is the muffler shield for the side step on the passenger side, so your passenger doesn't stick their foot into the hot muffler as they're stepping in.
Images: 768
Has thanked: 4649 times
Been thanked: 1432 times
Postby moore_rb » Sat Jul 25, 2020 4:30 pm
The piece on the right looks like the passenger side lower inner skirt for an early (pre 68) style fender... :think:
moore_rb Offline
Images: 70
PreviousNext
Return to General Tech
