Postby nizmut » Sun Aug 11, 2019 2:07 pm
What is this?
Robin
nizmut Offline
Has thanked: 55 times
Been thanked: 164 times
Postby Esteban » Sun Aug 11, 2019 2:40 pm
Looks like somebody capped the old style breather tube with that gizmo.
In older Patrols or in regions without emissions requirements, a chimney pipe coming out from that hole in the block allowed the crankcase fumes to vent freely.
Has thanked: 2889 times
Been thanked: 888 times
Postby nizmut » Sun Aug 11, 2019 3:19 pm
Guess I'll open it up and see if it is a pcv device.
Robin
nizmut Offline
Postby nizmut » Fri Aug 23, 2019 11:15 pm
What are you using for the heater fresh air flapper gasket?
Robin
nizmut Offline
Postby Mattbob53 » Sun Jan 19, 2020 7:38 pm
Body to frame bushings... two steal plates or one? Pretty sure I have seen both while talking apart.
Mattbob53 Offline
Has thanked: 27 times
Been thanked: 111 times
Postby moore_rb » Sun Jan 19, 2020 8:34 pm
Mattbob53 wrote:Body to frame bushings... two steal plates or one? Pretty sure I have seen both while talking apart.
One per body mount- Rubber against frame, then shim between rubber and body
moore_rb Offline
Images: 68
Has thanked: 568 times
Been thanked: 875 times
Postby Mattbob53 » Sun Jan 19, 2020 8:44 pm
Thank you sir, going to make some new shims, does it make more sense to put shim in middle? Metal on metal isn’t some thing im use to
Mattbob53 Offline
Postby Mattbob53 » Sun Jan 19, 2020 8:56 pm
Mattbob53 wrote:Thank you sir, going to make some new shims, does it make more sense to put shim in middle? Metal on metal isn’t some thing im use to. I made the rubber ones
Mattbob53 Offline
Previous
Return to General Tech
