my 1967 patina project build
Postby rdarnell » Thu Oct 10, 2019 10:56 am
That should work out much better... measures a little over 7 inches on the treadwidth. Super Swamper TSL 29x8.50R15.
6476
rdarnell Offline
Images: 188
Has thanked: 122 times
Been thanked: 222 times
Postby L60Boerne » Thu Oct 10, 2019 7:42 pm
Bingo!
65 No Top - Presidio Patrol
L60Boerne Online
Has thanked: 2 times
Been thanked: 797 times
Postby rdarnell » Sun Dec 15, 2019 8:41 pm
I was hoping to just re-ring the replacement engine that I bought but it has too much cylinder wear and will need to be bored. I guess since there is some boring planned maybe I should go back and see if the original engine is buildable. When I bought the truck in 2017 the head and pistons were removed maybe 15-20 years ago.
5549
Pulling out the lifters and cam I noticed they were in pretty good condition. The rod journals and cylinder walls have surface rust but I think they should clean up okay. I am not sure why they took it apart though. The head was missing but all the valve train and pistons were loose in the rear. I did notice that when pulling out the rear main cap the seals on the sides were missing.
6582
6586
6583
6584
6585
rdarnell Offline
Images: 188
Postby rdarnell » Fri Jan 31, 2020 1:44 pm
Engine parts came in today. 40 over pistons and 10 under bearings from Tiffin Parts.
6866
6850
rdarnell Offline
Images: 188
Postby rdarnell » Sat Feb 08, 2020 10:19 pm
Block and crank are back. Bored 40 over and crank turned 10 under. I think I will be painting the block cast color instead of black like original.
6880
6881
rdarnell Offline
Images: 188
Postby Esteban » Sun Feb 09, 2020 11:05 am
rdarnell wrote:Block and crank are back. Bored 40 over and crank turned 10 under. I think I will be painting the block cast color instead of black like original.
Beautiful! Nothing like having that fresh block in front of you, coupled with all the parts.
Please take a lot of sequential pictures. We have some good examples but always scattered pictures of the process and nothing complete.
The choice of color looks good and makes sense. Are you going to use high temperature paint? Mostly will matter on the exhaust manifold, as regular paint does hold in the rest.
Has thanked: 2929 times
Been thanked: 897 times
Postby rdarnell » Sun Feb 09, 2020 11:44 am
will do on photos. I am using cast iron color paint from Duplicolor it is engine enamel with ceramic. I have it on my Land Cruiser engine for the past 3 years with about 5000 miles and it seems to be holding up pretty good.
rdarnell Offline
Images: 188
Postby rdarnell » Sun Feb 09, 2020 9:21 pm
Block taped up and painted!
6882
6883
rdarnell Offline
Images: 188
Postby L60Boerne » Fri Feb 14, 2020 7:41 am
I sure wish I had one of those. You have more skill than Vegas has lights. That is a whole new meaning for over and under :clap: :lol:
Patrolling with parts from everyone,
L60Boerne Online
Postby rdarnell » Sat Feb 15, 2020 7:16 pm
Did not get any assembly done but I made some progress towards that. Got the new pistons on the rods. Unlike my Land Cruiser the connecting pin has to be pressed into the connecting rod. When I got the truck the engine was partially disassembled. I had to do some cleanup on the bearing journal ends of the connecting rods from where they had been sitting in the rear of the truck for 15+ years. Some of the head bolt threads in the block were a little dirty from having sat so long. I chased them and the main bolt holes with a tap.
6909
6910
6911
rdarnell Offline
Images: 188
Postby mad4hws » Sun Feb 16, 2020 7:27 am
She's looking really good. I wish I had your skills!
mad4hws Offline
Images: 231
Has thanked: 124 times
Been thanked: 207 times
Postby moore_rb » Sun Feb 16, 2020 9:52 am
rdarnell wrote: Some of the head bolt threads in the block were a little dirty from having sat so long. I chased them and the main bolt holes with a tap.
Always a good practice...
It's coming along very nicely. Good job finding brass freeze plugs- I searched high and low looking for brass when I ordered mine, but ended up settling for zinc plated steel ones.
moore_rb Offline
Images: 68
Has thanked: 573 times
Been thanked: 888 times
Postby rdarnell » Tue Feb 18, 2020 9:11 am
Got the freeze plugs and most of the other parts from Tiffin Forklift Parts, great guys to work with.
rdarnell Offline
Images: 188
Postby moore_rb » Tue Feb 18, 2020 9:18 am
I just noticed the pic of your super swampers...!
Coolest
Tires
Ever.
moore_rb Offline
Images: 68
Postby rdarnell » Thu Feb 20, 2020 2:23 pm
just got the head back from machine shop. everything checked out good.
6922
6923
rdarnell Offline
Images: 188
Previous
Return to Projects
