Rubber radiator mounts
Postby ozscott » Sat Mar 21, 2020 5:24 am
I have had the radiator recored of my 1978 Patrol. I would like to replace the rubber mounting washers that sit either side of the radiator mounting points. Mine are hard and very brittle. Does anyone know of a source for these mounts? They are domed in shape, like a 50's flying saucer, or do they just compress to that shape over years? Any guidance appreciated. Scott.
By th way my Patrol has been sitting 17 years, not 10 as I stated in my initial posting on "Show us your Patrol".
ozscott Offline
Has thanked: 4 times
Been thanked: 12 times
Postby Flaggoni » Sun Mar 22, 2020 3:30 pm
I made my own mounts. I used 1/2 inch thick neoprene from Mc master Carr. I used a bandsaw, then a disc grinder to make the discs. I used short pieces of heavy duty air hose for the compressible center isolators. Make them a little bit long, so they can expand in diameter when tightened.
Mild Bill
Flaggoni Offline
Has thanked: 188 times
Been thanked: 191 times
Postby ozscott » Mon Mar 23, 2020 5:05 am
Thanks for the detailed response. I take it that they are not easily found considering the work that would go into making a set.
ozscott Offline
Postby jwgreen » Mon Mar 23, 2020 3:35 pm
Check this place, they have them in stock it seems along with a bunch more rubber needed for the Patrol
https://sportsimports.ca/patrol-rubber
jwgreen Offline
Images: 70
Has thanked: 48 times
Been thanked: 272 times
Postby ozscott » Tue Mar 24, 2020 1:04 am
Thank you. :clap: I have contacted them. They seem pretty reasonable at $24 for 4. I appreciate the assistance. Scott
ozscott Offline
