I decided to expand my water-resistant work-on-cars area. Today I added this:
This evening, I added this!
faux40 wrote:Hydraulic clutch parts! Yea, that's right, I plan to ditch that clumsy, lumpy, mechanical clutch linkage for that smooth, gliding control one gets from a hydraulic clutch system!
Esteban wrote:Excellent pictures of the progress, John. Great to see your son working on it as well!faux40 wrote:Hydraulic clutch parts! Yea, that's right, I plan to ditch that clumsy, lumpy, mechanical clutch linkage for that smooth, gliding control one gets from a hydraulic clutch system!
I have to burst your bubble on this one. In both systems you apply exactly the same effort. You can only argue that the pivots of all the parts on the mechanical will increase a tiny bit the force needed. But don't get me started in reliability.
faux40 wrote:So, I was thinking of a couple options:
1) Change the two end bearings and seals and probably the pinion seal, then leave well enough alone. I will need a shop to help as I don't have a puller or a torque wrench that goes to over 200 ft pounds!
Rear Axle | ||||
Qty | Description | Nissan PN | Alt PN | Notes from Parts DB |
2 | Outer Grease Seal | 40227-32201 | Outer Seal: NOS-550225 48x65x7 mm https://www.napaonline.com/en/p/NOS550225 https://www.amazon.com/48x65x7-Rubber-C ... B00SVIPCFQ (per Esteban) | |
2 | Inner Oil Seal | 38212-01300 | Inner seal: ATM 2116213 35x55x11 mm https://www.napaonline.com/en/p/ATM2116213 (per Esteban) | |
2 | Wheel Bearing | 38440-25660 | Bower 30208, 40210-85000 NSK 30208 (stamped on the bearing that was on my axle) | |
2 | Bearing and Shaft Lockwasher | 43069-44000 | Whittet-Higgins W-08 Bearing and Shaft Lockwasher | |
Front Axle | ||||
2 | Outer Bearing | 40215-45460 | ||
2 | Inner Bearing | 40211-45460 | NSK HR 30209J | |
2 | Grease Seal | 40227-44001 | TCM Part 65X88X12TC-BX. Ebay item --replaces stock part 40227-44001 65 x 85 x 11-5 mm | |
2 | Roller Bearing | 40588-44000 | RUS305 | |
4 | Knuckle Flange Bearing | 40215-10360 | 30304A | HR30304BJ, Equivalent nissan number: 40215-P0100 |
4 | Knuckle Flange O-Ring | 40597-44000 | ||
2 | Grease Seal/Wiper | 40578-46500 | ||
Differential | ||||
2 | Pinion Oil Seal | 38189-44000 | https://www.avxseals.com/Shaft-Oil-Seals-TC50x73x12-p/tc50x73x12.htm |
