Timing Gears and associated parts.
Original and compatible parts
Postby DatsunDave » Mon Dec 21, 2020 12:26 pm
I have searched and there are discussions here about the differences between the P and the P40 timing parts but I haven't actually found any info on timing set parts for the P.
I am on the verge of an engine rebuild but if I can't get timing gears and associated parts it seems like a rebuilt isn't possible.
Any advice?
DatsunDave Offline
Has thanked: 3 times
Been thanked: 4 times
Postby 50car » Mon Dec 21, 2020 9:04 pm
The P motor is gear to gear so normally, no replacement is required. If the aluminum gear attached to can shaft is damaged, there are members on this site who have spare parts.
Jeff
50Car
50car Offline
Images: 327
Has thanked: 473 times
Been thanked: 267 times
Postby DatsunDave » Tue Dec 22, 2020 12:22 pm
50car wrote:The P motor is gear to gear so normally, no replacement is required. If the aluminum gear attached to can shaft is damaged, there are members on this site who have spare parts.
So, it is used parts (which is fine of they are good) or nothing. Correct?
DatsunDave Offline
Postby Esteban » Tue Dec 22, 2020 9:27 pm
Correct.
The gears will probably be fine. I’ve had Patrols with over 100k at a rebuild, and the gears were fine. My current engine, has two rebuilds done and the gears were not changed.
When the tim comes, please post some pictures of them.
Has thanked: 3881 times
Been thanked: 1037 times
Postby jwgreen » Sat Dec 26, 2020 5:39 pm
You can sometimes find the gears on Amayama but they are PRICEY!!
http://www.amayama.com/
jwgreen Offline
Images: 70
Has thanked: 82 times
Been thanked: 389 times
Postby plateaucal » Sun Dec 27, 2020 9:29 pm
But, engines rotate differently South of the equator...right. So would the parts work, but only in reverse?
plateaucal Offline
Has thanked: 250 times
Been thanked: 617 times
Postby DatsunDave » Mon Dec 28, 2020 10:00 am
jwgreen wrote:You can sometimes find the gears on Amayama but they are PRICEY!!
How? Their drop down list for years doesn’t go old enough. Hmmm?
DatsunDave Offline
Postby jwgreen » Mon Dec 28, 2020 8:15 pm
Just use the part number in the search box. You can find that in the parts manual that you can download from the forum.
jwgreen Offline
Images: 70
cron
