Fuel Pump
- Has thanked: 6018 times
Fuel Pump
This is for the P40 engine, that's exactly the same.
Part #: 17010-L6200
copy the part # into the search field here:
http://www.forkliftpartssupply.com/home.aspx?Page=Parts
$130 (May-2013)
Part #: 17010-L6200
$130 (May-2013)
- Has thanked: 310 times
- Been thanked: 176 times
Re: Fuel Pump
Dude!......Maestro!.........Esteban wrote:This is for the P40 engine, that's exactly the same.
Part #: 17010-L6200
$130 (May-2013)
- Has thanked: 54 times
- Been thanked: 17 times
Re: Fuel Pump
Great Job Esteban, any chance if you found out about a rebuild kit? I see they have a bunch a "gaskets" listed but no pics..
(insert clever saying here)
Re: Fuel Pump
I have no idea. I had the link above saved from a few years ago, that somebody posted on the internet.norville wrote:...any chance if you found out about a rebuild kit? ...
Although all the fuel pumps made over the years are exactly the same on the outside, the diaphragm leg changed in two or three slightly different lengths (probably under the advice of the accountants) so they are not interchangeable.
I had a diaphragm from the early 70s and it fit perfectly on a pump that came from a 1983 P40 engine.
Re: Fuel Pump
good to know , that's the part that most rebuilds need..Esteban wrote:I have no idea. I had the link above saved from a few years ago, that somebody posted on the internet.norville wrote:...any chance if you found out about a rebuild kit? ...
- Has thanked: 181 times
- Been thanked: 174 times
Re: Fuel Pump
OEM available from Nissan, part # is 17010-C6028
http://www.amayama.com/search?q=17010-C6028
Other part numbers that work are,
17010-C6086
17010-C8025
17010-C6086
17010-C8025
- Has thanked: 84 times
- Been thanked: 327 times
Re: Fuel Pump
Great info. Cheers Ian!RMP&O wrote:OEM available from Nissan, part # is 17010-C6028
17010-C6086
17010-C8025
- Been thanked: 15 times
Re: Fuel Pump
Hi Esteban,
I'm rebuilding my fuel pump, and unfortunately I received a rebuild kit from NAPCO, 71-0185. The bottom of the box says "Nis-P 1971.......
So, I'm assuming I purchased the incorrect rebuild kit. ARRRRGGGG!!!!
So, I have a 1967 Nissan Patrol. Should I go ahead and just order the forklift fuel pump that you mention in the post? Thank you for your suggestions. I really want to get this puppy running and you and River Patrol both have such great posts.
I apologize if this was posted previously.
Thank you,
Darren 7/28/2026
Thank you,
Darren 7/28/2026
Re: Fuel Pump
Hi Esteban,
So, yes, I checked your post for the Forklift post,
https://forkliftpartssupply.com/product ... 11c8939d2d
and I notice they are not available any more....and $660 bucks.....whew........
Any suggestions on where to purchase a rebuild kit for a fuel pump for a 1967 Patrol.......I'm a newbie, and just getting used to the forum, etc.......
Re: Fuel Pump
With that outrageous price for the fuel pump at a couple of sites, I will install an electric fuel pump in the meantime. A universal electric fuel pump 4-7 psi will do it. I think a couple of members have done it. I would go that route in a heartbeat if that was my case.
Some purist here will not like it, but you can keep the old pump covering the hole and wait until the repair kits could be sourced. In Colombia and Australia you can definitively can find, if you have a contact there.
Member KansasPatrol was trying to see if another pump he found could be used. Try contacting him. See this threadÑ
https://www.60patrol.com/forum/viewtopi ... k00#p54844
